Driver's Side Window
My Driver's Side window fell and I don't know how to fix it
The motor still works, its just that the window doesn't catch and its stuck inside the door~
anyone have a clue to how to fix it?
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Sweet as Gold
replace your driver's side window regulator assy...you must remove the door panel...then remove the regulator while holding the door glass in the fully closed position...once you remove the bolts for the regulator...the glass will slide up. It's pretty simple.
Also if it's not an actual problem...like a faulty part or something...then take off the door panel and window run channel and you should be able to free it up!!
East Coast Boost.!
Ant works at acura what do you expect.
If you got common sense, this is what you do. take off the door panel, unbolt the track, and slide the window back in.
Sorry ant, I know what you're saying, but you know the guys on this board.
'Big Daddy Diggler'
I'd just take the inner door panel off, take off the track and line the window back up. Or if you are not mechanically inclined, just take the car to the dealer for a quick warranty fix.
Sounds like the window regulator has a faulty cable on it .Nothing you can do but replace it .Your dealer probably stocks them ,I know we do here at PAA .This is not an uncommon thing to happen so even if your car is out of warranty they may goodwill it for you .
Jens
Jens
acura_dipset_tl
01-01-2016 03:02 PM
sockr1
10-01-2015 01:31 AM
ahsm
09-09-2015 08:35 AM
