Does Dynomat help at all???
I am about to purchase some Dynomat but Im only pushing 500 watts to an Infinity Perfect sub I don't know if it warrants Dynomat..I posted in the A/V section but nobody browsing and Im about to buy it online. Any help please!!
Originally posted by bnavarro
i heard a difference after putting it on the pannels on my trunk and rear quarter pannels.
Lou, with the amount of power you're running...I would recommend "FatMat" It's a fraction thinner than Dynamat, but half the price. A Dynamat trunk kit runs for $99 (36sq Ft) when a Fatmat kit runs for $49(36sq Ft) or you could get 100sq ft for $99.
Price is a good reason but which is great cause this is gonna be a one time deal no do overs If u know what I mean
I bought the Dynamat kit before I knew FatMat existed. I put all 36sq Ft of Dynamat into my trunk, but I haven't put it to the test yet. I bought 36sq ft of FatMat to do parts of the interior and any other parts of the trunk that may vibrate after the system is in there.
Dynamat is thicker which helps reduce more vibration than FatMat, but twice the price. If you wanna be on the safe side...go with Dynamat. I think you can request a sample from both companies and then you can make a decision.
500W...what Htz are u running at. If it sounds good in terms of BUMP, but is missings the nice hmmmmmmmmm of DEEEEEEP bass. I would recomend running it at 80 Htz.
Juker008
Juker008
Juker008
Juker008
Got BOOST????
You don't need that much dynomat. You dont need to do the bottom of the seats, or the bottom of the trunk. It already comes from the factory like that. it has a thin mat as it is. i would do the trunk lid, the rear quaterpannels, the front doors, and back deck. the trunk lid, i didn't use a whole sheet. just in between the X.
Sounds to me that u need to dynamat the trunk. But 1st, what enclosure are u using? What is the cubic air space that the box holds. Also what is the range of the air space that the speakers run at.
My theory to this situation is if u have BUMP at 500W it sounds to me that u are using a sealed box. If that is the case 1st go with polyfill stuffing. Use like 2-3 punds of the stuff. That will make the box think that it is bigger and u will then get that HMMMMMMMM.
Get back with me on the specs of the box and the subs. And if u want go ahead and stuff the box. Pollyfill stuffing is CHEAP and u can get it at any crafts store.
Juker008
Juker008
Juker008
Juker008
Thanks for the help.
subdued
03-27-2007 02:11 PM
ed99
15
02-03-2005 02:25 AM
