Diff between VTEC and i-VTEC
Old 03-20-2002 | 05:20 PM
chrw's Avatar
Member
As subject says, what's the diff? If i-VTEC is the newer version of VTEC, why doesn't the 03CL have it?
Old 03-20-2002 | 05:56 PM
LegendC's Avatar
The Acura Granddaddy
The difference is that an i-VTEC motor can change its valve timing in addition to lift and duration. Normal VTEC only changes lift and duration of the valves. Being able to advance and retard timing is vital to extracting even more power out of a motor and keep its daily drivability.
Old 03-20-2002 | 06:33 PM
Styles__69's Avatar
yeah but the question still remains..
why wouldnt they put that on the CL than?
Old 03-20-2002 | 06:36 PM
Zapata's Avatar
Cost Drivers!!!!
They will. Every acura engine will have ivtec by 2005. Next gen cl in 2004 should have ivtec. '03 NSX is rumoured to be a ivtec 4.0L v8 or possibly an ivtec 3.5L v6.
Old 03-20-2002 | 06:51 PM
Speed_Racer's Avatar
6 Forward 1 Back
I thought I read also that i-VTEC gives you more bottom end torque? Is that true? Is this also one of the reasons that the RSX Type-S has such a quick 0-60 time. . .
Old 03-20-2002 | 06:55 PM
typeR's Avatar
yep...i vetc makes better torque...i vote the 2004 gets a 3.5 i-VTEC 300 hp/300 lb.ft.??? do i have any nay's?.
the i's have it then...
Old 03-20-2002 | 07:09 PM
kHmER Co's Avatar
mister D
If CL's last that long
Old 03-20-2002 | 07:20 PM
acura_service's Avatar
www.drippinwet.com
i think the new interceptor has it
Old 03-20-2002 | 07:22 PM
gavriil's Avatar
Moderator Alumnus
I doubt 300 pounds from a 3.5 liter but for sure 265 pounds. Torque is hard to make because it is much dependant on engine displacement. You can make all the power in the world by making it spin faster, but torque will go up marginally.
I am sure you know what I mean.
Old 03-20-2002 | 07:28 PM
23wt's Avatar
Mugen Racing Team
I heard that the new i-vtec is not that great for modding and if i-vtec is compared with vtec, vtec is better.
Old 03-20-2002 | 07:49 PM
typeR's Avatar
the funny thing is..i edited my post...i first said 300/275...but i liked the sound of 300/300 so...hey i can dream...
Old 03-20-2002 | 08:01 PM
EricL's Avatar
They remove VTEC too....
The I-VTEC would be helped with DOHC. Variable timing with SOHC is "tricky".
A lot of the "race" folks remove the I-VTEC and the tighter the gearing (gear ratios), the less need there is for it.
In "everyday" situations, where emissions are very important, it is very helpful to keep the torque up, while allowing the overlap and duration of the cams to be used to gain torque (and power) and to control "quenching" and exhaust dilution that can help with N0x control.
Old 03-20-2002 | 10:10 PM
JZ's Avatar
JZ
I don't think there is any question the next engine will be the 3.5L i-VTEC with 300hp since it already exists............in the Honda Dualnote.
Old 03-20-2002 | 11:34 PM
Nashua_Night_Hawk's Avatar
Happy CL-S Pilot
I will be happy guy trading my CLS for a 2004 TL-S with 300HP/300lbft . Just give me 4WD. otherwise, torque steer and wheel spin will spoil the fun.
IBankMouse
06-13-2020 12:53 PM
Dunnik
09-15-2015 11:52 PM
Desert Ridge
09-05-2015 09:47 AM
LAMike240
09-03-2015 04:35 PM
DRR98
1G RDX Problems & Fixes
09-02-2015 10:52 AM
Quick Reply: Diff between VTEC and i-VTEC
