Dei Shock Sensor From Autotoys
okay I took a risk since the "brand" name of the shock sensor at autotoys wasn't listed, and it came out to be the infamous "DEI OEM ALARM INTERFACE", now I want to return this thing and go buy the other one, you think they will take returns, will i have to pay for shipping?
http://www.acura-cl.com/forums/showt...i+shock+sensor
says that the DEI shock sensor isn't sensitive, and doens't seem to work properly, i'm looking to get that gargoyle one that cor posted on a bit ago, for 4 bucks, i just might buy a few, anyone know if the gargoyle from crime stoppers is any better?
just read the invoice and it says no returns or exchanges of any kind, so it looks like i'm stuck with this thing, 22.50 for a piece of junk, i don't even wanna open it or install, anyone looking to purchase this, if they have faith that it will work? haha, i guess i'll try it on ebay or something
how bad can this thing be tho??
Originally posted by Neech
I thought DEI was one of the best?! Maybe that guy didn't mount it in a good spot for shock?
I think the DEI's work great w/ the DEI alarm brain, but not w/ our factory ones for some reason
you think I will be able to ebay this thing, it has no use to me since i'm trying to maintain my stock shock sensor
people with gargoyle crime stopper one, how well does it work?
Damn.... $22.50.... the shock sensor I bought from there was only $10.50 and it hooked up fine following Nova's instructions. I specifically stayed away from DEI b/c of those same instruction.
There is nothing wrong with the DEI sensors. I am using one in my car. What you have to do is use the first stage wire since it is the most sensitive. Where you mount it is also important. mount it to a structural part of the car. For me, I mounted mine behind the glove box on the tubular cross frame. IF you want more sensitivity, connect more than one. Put one in the rear, and one in the front.
Shock sensors merly output 12v- when triggered, so it doesn't matter what they are hooked to.
is yours hooked to stock alarm? which wire is the first stage wire, and how did you get it to mount behind the glove box? any pictures? thanks, maybe i will keep this thing
CL-S progression 01
Jan 26, 2016 04:15 PM
