Custom Poly Engine Mounts
Old 01-15-2009, 11:13 PM
  #81
I'll put you in the wall
J32A26MT's Avatar
Can't wait to do this now. I just need it to not be 20 degrees and find the time to pull my mounts one by one, or find some extra used ones, or buy new ones.
Old 01-16-2009, 08:49 AM
  #82
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Nice, i will also be dong this, as i have gone thru 2 fronts since i did the manual conversion 2 years ago.
I will also be adding a "dog bone" style motor mount (like GM has on their FWD cars) soon and will update/create a thread as soon as i do. My hope is to take more stress off the motor mounts and eliminate the motor from twisting as much without having to have solid mounts to cause vibrations.
Old 01-16-2009, 11:16 AM
  #83
I got the Shifts
phee's Avatar
just take chicken wire and strap the motor down
Old 01-19-2009, 03:48 PM
  #84
Lamborghini Aventador FTW
AMGala's Avatar
Thanks for the DIY, my front mount is broken so I'll be doing this to my new mount.
Old 01-19-2009, 04:05 PM
  #85
chtrcy's Avatar
I have seen them when Kevin brought them over. Very solid and worth the money for the poly. I will be doing mine soon.
Old 01-25-2009, 08:57 PM
  #86
distortedolskool's Avatar
so just finished my 400 mile weekend dallas trip. car still has wheel hop and it might be slightly more than with the innovative mounts. i'm also not sure if that has to do with the fact that the dampers are still out. i'm going to reinstall them this week and see if that helps. currently i'm thinking that the increase is due to the front since the stock design is so different that the aftermarket.
my next step might be to try the 80a poly on the rear mount. but that's $100 just for a new mount!
Old 01-25-2009, 10:34 PM
  #87
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,182 Likes on 4,827 Posts
I was planning on using a firmer poly when I do mine.
Old 01-25-2009, 10:50 PM
  #88
here are the tensile strength listings for the poly i used
60a 1250
80a 1725
94a 3120
i'm afraid the 94 might be to hard but it still says flexible urethane.
Old 01-25-2009, 10:56 PM
  #89
and correct that $100 from before.....it is $140 for the rear alone. i'm thinking the 80 might not be that big of step up from looking at the psi ratings.
Old 01-25-2009, 11:41 PM
  #90
civicdrivr's Avatar
They don't sell 88a?
Old 01-25-2009, 11:46 PM
  #91
civicdrivr's Avatar
I wonder since the entire mount isn't being made out of this extra poly, would the 94a truely feel as firm as it suggests?
Old 01-26-2009, 12:46 AM
  #92
I got the Shifts
phee's Avatar
where do i order this stuff? whats its name?
Old 01-26-2009, 08:03 AM
  #93
CleanCL's Avatar
kevin -
You can get the mount for $111.86 + s/h here: http://oemacuraparts.com
Old 01-26-2009, 12:00 PM
  #94
thought about the same thing last night. on the rear i did leave the fluid and other rubber intact. i would like to see someone try the 80 and report back but i don't think it will give me the improvement i want. 94a is going to be my next step...i just hate taking off the comptech bar every damn time.
jermey: thanks for the link! saved me the cost of my poly.
Old 01-26-2009, 12:15 PM
  #95
Wide Body 3.2 CL-S
krazykrnboi's Avatar
keep us updated distortedolskool.
Old 01-28-2009, 11:41 AM
  #96
civicdrivr's Avatar
Where did you buy the poly?
Old 01-28-2009, 12:54 PM
  #97
MP90 uninstalled
jproy's Avatar
post #50
http://www.mcmaster.com/nav/enter.asp?partnum=8644K24
Old 01-28-2009, 05:20 PM
  #98
poisx7's Avatar
Old 01-28-2009, 05:27 PM
  #99
DAMN a 3.8 swap!!
oh ya the dog bone. we need to figure out a nice mounting spot for one.
Old 01-28-2009, 05:30 PM
  #100
poisx7's Avatar
yeap the dog BN.
Old 02-05-2009, 02:00 PM
  #101
J32A26MT's Avatar
found some good deals on front and side mounts...anyone got an extra rear?? best price i got is $81.84...
I'd like to use the 94 on the front and side and maybe something softer on the rear like 80.
how much of this shit needs to be ordered to do all the mounts? are there different sizes available?
Thanks Distorted...
Old 02-05-2009, 02:32 PM
  #102
civicdrivr's Avatar
x2 on the amount used for all the mounts. Im gonna run 94a.
Old 02-05-2009, 04:56 PM
  #103
2 of the smaller cans do all the mounts. i still haven't purchased the 94a as i wanted to reinstall my rear damper but i can't find it. anyway i doubt it will help that much. i will order a new rear and 94a tomorrow. i'm not going to redo my front or side quite yet.
Old 02-05-2009, 06:08 PM
  #104
Fuck it. just ordered the rear mount and poly. when i do this i will put my rear 60a poly filled mount up for sale. great for a daily looking for something a little extra. or i will attempt to cut the guts out and make it solid poly like my side mount.
Old 02-05-2009, 06:53 PM
  #105
MP90 uninstalled
jproy's Avatar
Dont do it yet! I have some good info for you about this. I think there is a flaw in how you did your front mount that is giving you too much movement. I have cut one in half, cleaned it, and taken photos. I just poured the side and front mount with 60A. It took all of one small can of 60A. I currently think the best way to do this is 40A complete fill of the front (like I will show you), 60A in the rear, 40A on the side mount, and 60A on the two trans mounts without cutting out the existing rubber. I have all the poly and extra mounts so I will be trying all this soon. The way you filled your front mount there is no more additional limit on the ability of the mount to stop the front of the motor from lifting up. The way you have it, the front of the motor has only been limited from moving down as much as the OEM will allow. Give me some time or call me.
Old 02-05-2009, 07:40 PM
  #106
i have altered my order.
jproy - great discussing these mounts. thanks!
Old 02-06-2009, 03:22 PM
  #107
MP90 uninstalled
jproy's Avatar
We are going to make this work, WELL!!
Old 02-06-2009, 03:35 PM
  #108
Unregistered user
LIPPSTUH's Avatar
last 3 posts are so but sounds great.
Old 02-07-2009, 12:41 AM
  #109
civicdrivr's Avatar
argh! cut me in on the details! i just ordered all new mounts to do this and i want to do it right.
Old 02-07-2009, 06:42 AM
  #110
well just hold on to your new mounts for a second. the details and bugs are being worked out.
the six speed rear mount is pretty much solid rubber towards the bottom, below the pin. i didn't cut anything out so the poly poured about 1/4" thick over this area, figured it might be an issue. the poly didn't adhere to the rubber and from the weight of the engine is flared out. i will do a little sketch later this morning after i get back from work. this bottom rubber will need to be cut out so that the poly can fill from side to side below the pin and adhere to itself. i was just about to jump back into the motor and redo the rear when jproy brought up the front mount issue.
i have ordered more poly and am going to add some to the front mount this week hopefully reducing hop. i will be taking pictures and such.
so for the clifs...just standby a few weeks with your mounts and poly. you have the correct materials, now just let us work out the kinks.
Old 02-07-2009, 08:35 AM
  #111
here is a cross section of the mount before and after. The red represents the rubber and the yellow is the poly. i know there is a small amount of rubber at the top but i remember the poly pouring completely through. from the weight and the poly not being able to act as one system, has allowed the "flaps" to flare outward.
Old 02-08-2009, 10:56 PM
  #112
civicdrivr's Avatar
Ahhh, I see.
Is that the same issue with the front mount?
Old 02-09-2009, 06:02 AM
  #113
Ahhh, I see.
nope. the front mount issue is that the rubber i poured takes care of compression but i did nothing to help tension when the engine torque pulls up on the front mount. that is what jproy brought up and we are currently working on. i'm waiting to get my extra poly this week.
Old 02-09-2009, 10:32 AM
  #114
I got the Shifts
phee's Avatar
:jizz:
Old 02-09-2009, 01:46 PM
  #115
fsttyms1's Avatar
Originally Posted by poisx7
This is what im going to be working on in a few weeks.
Old 02-09-2009, 03:31 PM
  #116
MP90 uninstalled
jproy's Avatar
Thats going to be nice if you can find a solid place to mount it at the top of radiator. Cant wait to see what you come up with!
Old 02-09-2009, 04:20 PM
  #117
fsttyms1's Avatar
I know the upper support isnt stiff enough (not like the GM units) But i am working on a bracket either from the front or the rear for it.
Old 02-09-2009, 06:39 PM
  #118
MP90 uninstalled
jproy's Avatar
I knew it was not and wondered what you would do. I think you should start your R&D with the part at the front of the motor, however that would work. Attaching it to the firewall side will probably send those vibrations straight through to the cabin. I wonder if the strut brace would cut it? Keep us posted.
Old 02-12-2009, 12:23 PM
  #119
JCharged's Avatar
Looks to be my next alternative. Great work thus far guys. Time to ditch these Innovative mounts.
Old 02-12-2009, 12:38 PM
  #120
fsttyms1's Avatar
Well with the rubber in the ends i think it would keep vibrations from coming into the cabin. Either way i will be playing and trying to figure something out.
Quick Reply: Custom Poly Engine Mounts
