CT Sway bars
Old Jan 13, 2006 | 04:34 PM
All Mine's Avatar
I'm a Vagiterian.
CT Sway bars
I have a chance to get basically new CT Sways. Is it true the rear one is basically pointless to install, due to it's size being the same as stock? Should I sell it and upgrade to an '04 TL bar?
Old Jan 13, 2006 | 08:57 PM
typeR's Avatar
its the front that is the exact same size...the rear is atleast 2mm larger but if i remember it's 3 stock 19 comp 22 ? but on the front what is still in question is the wall thickness...stock is hollow and so to is the comp but were told the wall thickness is greater but never got an answer on how much...
Old Jan 13, 2006 | 10:43 PM
brado's Avatar
new wheels = old school
yeah, when i installed my bars, the fronts look the same, but the comptech sway is def considerably heavier. the rear is what is MOST important. good luck.
Old Jan 14, 2006 | 08:29 AM
phipark's Avatar
Not Asian
Still speculation on the front wall thickness.
The rears:
Stock - 19mm
CT - 22mm
Eibach - 23mm
Old Jan 14, 2006 | 08:58 AM
Sun Diego CL-S's Avatar
says "hello to my TLX".
crazy ryan is always getting his hands on some goods. :wink:
Old Jan 14, 2006 | 02:14 PM
Allout's Avatar
Blown is Best
Interesting that on the 04 TL, they only sell the rear bar. Others have purchased the 04 TL rear bar and have had good success with it on the CL.
I went from a set of Comptech sways to the Neuspeed set with the rear race bar. I was pleasantly surprised that the difference is significant between the two.
Old Jan 15, 2006 | 12:33 PM
xenolite's Avatar
In my opinion we only really need the rear bar.
I have the Eibach rear installed only and it feels nice.
A stiffer front bar increases understeer, which I assume you're trying to eliminate.
So if you install both you're removing some of the effects of the rear bar but eliminating some front body roll.
Old Jan 15, 2006 | 11:36 PM
VeeralS05's Avatar
I NEED MONEY!
yeah the rear made the main difference for me... the rear end came around much quicker...but for the front you can get the CT Strut bar and maybe the cusco underbody tie bar... thats wht my plan is...
Old Jan 16, 2006 | 10:15 AM
6MTpromises's Avatar
Relax!
Hey Allout, could you elaborate on the nuespeed rear race bar? Is that something seperate from the regular 19mm rsb that neuspeed sells for the 2G CL? And the handling was improved over your previous comptech setup?? Thanks man!
Old Jan 17, 2006 | 12:25 PM
phipark's Avatar
Not Asian
The rear race sway bar by Neuspeed as been discontinued. It was something like 26mm thick, maybe too thick for our endlinks.
Old Jan 18, 2006 | 03:20 AM
RooEng's Avatar
Check out EricL's post, lots of good info.
https://acurazine.com/forums/showthr...ighlight=0.177
tsx_boy
Dec 13, 2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
hashbrown
Sep 29, 2015 12:13 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
