Crank Trigger..
Originally posted by Zapata
This dude is putting together and ECU and doesn't know where the crank trigger is??????
Originally posted by moomaster_99
Every car is different..and I am not about to let my car be torn apart so they can check the crank trigger.
You can build it without knowing the number of teeth on the crank trigger. The software is what will be dependant on knowing. The high speed counter is dumb and will work counting pulse but to determine what to do with these counts is in the software.
I'll also see what I can find out but for some reason I remember seeing 12x but I could be wrong. I'll dig on this when I get home.
The reason being that the Lexus crank has like 2 teeth missing and that their ECU knows this and overrides it....when the new ECU is hooked on....it sees it...doesnt know what it is...and stalls...
I wonder is the missing teeth are for a zero reference?? This is not uncommon in high speed industrial applications to use an interuption of the pulse inputs to act as a zero trigger.
Im not looking for the CRANK TRIGGER.. I need to know HOw many Teeth are on the CRank for the trigger to pickup..
Thanks for your help.. It's for the Software that i need to write for the car before tuning
Anyway, people were refering to the crank trigger as the the CPK, or crank position sensors which is what reads the pulses from the gear teeth. Just trying to isolate the area...
It should say in the Helms manual how many teeth are on the crank .. where the Crank Trigger pics up..
And thanks for all you guys help..
Scalbert.. give me a call.. I wanna know the new info..
LEo
LEo
I wasn't able to track it down in the manual but it appears Nashua was... What pages was that??
Originally posted by Nashua_Night_Hawk
Could u scan page 6-28 and email LEO.. I do not have access to a scanner.
acuratl26
04-23-2020 07:30 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
