Crank Pulley DIY?
Old Apr 28, 2014 | 08:03 AM
Scottyknows007's Avatar
Crank Pulley DIY?
Anyone have the link to a DIY crank pulley thread. I know I saw one on here before but cant find it now. Trying to get a guide before I do a lightweight crank pulley myself.
Old Apr 28, 2014 | 08:16 AM
CL-S progression 01's Avatar
lowrd on tein CS biatch
you will not be able to get the crank bolt off unless you have a 1000ft/lbs tq impact gun.
that was the only mod i brought my car to a shop to do.
that only way around that is to use the starter method.
get a breaker bar with the correct socket and rest the end on the ground. Then blip the starter/ignition and when the engine turns over it should power through the bolt. make sure you remove the fuel pump relay or else you may end up actually starting the car and then your breaker bar is going for a ride through the engine bay LOL.
I like many got cold feet when hearing this starter method and opted to let a shop do my pulley.
but if u wanna do it urself, i am sure the starter method will suffice.
Old Apr 28, 2014 | 09:23 AM
What about the harmonic balancer? Am I gonna have to mess with that?
Old Apr 28, 2014 | 09:39 AM
JarrettLauderdale's Avatar
What is it that you are under the impression an lightweight crank pulley replaces?
Old Apr 28, 2014 | 09:42 AM
My crank pulley, which frees up some of the power because its lighter weight. But I was under the impression the harmonic balancer had a part with the crank pulley? Does it not?
Old Apr 28, 2014 | 02:59 PM
The harmonic balancer IS the crank pulley in factory form.
Old Apr 28, 2014 | 03:09 PM
TheWeez's Avatar
I Wanna Beer
Been covered here a ton of times.
It's been posted in the FAQ too.
https://acurazine.com/forums/2g-cl-frequently-asked-questions-52/
Old Apr 28, 2014 | 08:24 PM
The harmonic balancer is another way for saying a tank. It's a monstrosity when you feel what it weighs to a lightweight aluminum one.
Old Apr 28, 2014 | 09:21 PM
o yea? You know if that crank bolt is a right handed thread or a left?
Old Apr 29, 2014 | 01:35 AM
Karanx7's Avatar
Unregistered Member
I and many people have used the starter method to get it off.
Worked beautifully.
Old Apr 29, 2014 | 10:10 AM
TheWeez's Avatar
I Wanna Beer
Worked beautifully.
This. Long breaker bar to keep it held. Pull the fuel pump fuse so it doesn't turn over. Really quick tap on the starter to pop it loose.
Old Apr 29, 2014 | 12:05 PM
Does the bolt come off counter clock wise? there is nothing different to taking this bolt off right?. Any special torq spec's for tightening it back down?
Old Apr 29, 2014 | 12:27 PM
TheWeez's Avatar
I Wanna Beer
Countless threads on the subject. Search is your friend.
https://acurazine.com/forums/2g-cl-2001-2003-50/crank-pulley-nut-754950/
https://acurazine.com/forums/2g-cl-2001-2003-50/crank-pulley-bolt-questions-716419/
https://acurazine.com/forums/2g-cl-problems-fixes-70/belt-pulley-change-730136/
https://acurazine.com/forums/2g-cl-2001-2003-50/removing-ur-crank-pulley-685149/
https://acurazine.com/forums/2g-cl-2001-2003-50/option-racing-pulley-install-494815/
Old Apr 29, 2014 | 11:26 PM
Rapture's Avatar
I took mine to a shop. Cost $100 total even the mechanic was having a helluva time getting the old pulley off.
Old Apr 30, 2014 | 01:01 PM
TheWeez's Avatar
I Wanna Beer
I would remember that these are now 11 year old vehicles (12 really). It can be a lot harder to get parts moving that haven't been removed in that time. May be worth saving the headache by just going to a shop and having them deal with it. Then they have to fix it if they break anything.
Old Apr 30, 2014 | 02:45 PM
Yea very true! I'm gonna call around the shops around here and see what it'll cost to get it done. Thanks for the
Old Apr 30, 2014 | 07:36 PM
Rapture's Avatar
absolutely. I still remember how hard it was to get the stock vacuum and coolant hoses off their ports when I did my CAI install. And that was like 4 years ago.
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
scionxb3003
Sep 22, 2015 05:28 PM
