couple a quick ice box questions 6MT
does the ice box connect directly to the TB or should there be any factory extension? and i heard the instructions suck...i have installed my aem several times so....i dont think ill have a problem...but any tips will be appreciated...
I now drive an accord....
http://www.acura-cl.com/forums/showt...ghlight=icebox
That is thoughts from my install
Yes the icebox connects directly to the TB. I beleive on the autos it connects to the VSA.
Where is my super sauce?
The main plastic tube connects to the throttle body with a corrugated rubber connector.
The intstructions aren't that bad -- they just show one bracket backwards (it's pretty easy to figure out the right way) and they say to take off the bumper which you don't have to do.
Don't forget to bleed any bubbles out of the coolant system after you install the Ice Box.
Look at the instructions yourself at http://www.comptechusa.com/instructions/ins110.pdf
Originally Posted by typeR
why would bubbles get in the coolant from changing out an intake and how would one do it anyway?
I've actually written this up before on these boards, so I'll paste:
Yes, you should bleed the air out of your system after you change the tubing. A large air bubble in the system is not going to be effective to cool the cylinder/block.
It's a pretty easy process - at least my poor man's version of it. If you are really anal you may want to do a complete coolant drain/refill procedure, but this'll do.
First off, you will lose some coolant when changing the tubing, so buy some Honda Type II coolant (premixed) before you install the IceBox as you may need to top off the system. It's good to have a jug of this in the garage as it is. Now is the time to buy some.
After the install you'll want to get the air bubbles out of the system. Remove the cap to the radiator. Turn on car and warm it up in idle about 10 minutes (IIRC, I think technically it's warmed after the radiator fan cycles twice). Turn up heater to max (IIRC, set auto to 90ºF) to open the heater core so the coolant circulates freely. During this process tap/jiggle the the coolant hoses (especially the large upper one) to move the larger bubbles to the top. Don't hurt your fingers -- be careful. You should see several large bubbles percolate through the opening that the cap goes too.
After a few minutes of this the bubbles should stop. You have now bled your system of bubbles. Top off any lost fluid in the radiator or reservoir, put on cap, turn off engine.
well just got back from the test drive...it's quieter than i expected...quieter even then the stock air box with lower resonator removed....slightly dissappointed i was hoping for a deeper sound like the afore mentioned stock air box.as far as gains...ill with hold there until i get a better chance to drive...it's late and still damp
cycdaniel
12-17-2019 10:58 AM
