Coolant Smell
Old Sep 19, 2006 | 07:49 AM
habla_punta's Avatar
Coolant Smell
Hey guys,
Recently I have been noticing a coolant smell after driving my car (01 CLS). Last night I changed the oil and did not notice any coolant leaks. I rarely use the AC. The car has ~75k on it.
Should I take it into the dealer?
Old Sep 19, 2006 | 08:34 AM
Moodist's Avatar
It could be a very small leak that you don't notice. Do you see any liquids under the car after it has been parked all night?
Old Sep 19, 2006 | 08:47 AM
Thanks, I'll try that tonight. I did fill the coolant reservoir last night, because it was dry...
Old Sep 19, 2006 | 01:37 PM
g1underground's Avatar
Cosmic Cowboy
Check your heater core under your dash. If they go bad you can smell coolant.
Old Sep 19, 2006 | 02:59 PM
fuzzy02CLS's Avatar
I was thinking that too, but it's such a newer car I didn't think it would be a problem already.
It's common on old cars.
Old Sep 19, 2006 | 03:06 PM
Thanks guys.
I don't smell it inside the car unless the windows are open. I took a peek under the hood with a buddy and he noticed some dried green substance below the thermostat housing. I spoke with a tech at my local Acura dealer and he said it could be a loose hose, cracked housing or bad gasket. He also said there is pretty much no way it's the head gasket. They'll check it out Saturday.
Old Sep 20, 2006 | 12:06 AM
blingbling69k69k's Avatar
CLS is gone.. H22 TEG NOW
take it in to a shop for a radiator check up... it should be free, but if they find leaks or busted host... they charge for repair
cycdaniel
Dec 17, 2019 10:58 AM
merc009
Jan 27, 2016 10:34 AM
LeVeL
Oct 18, 2015 04:19 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
