Converting a '01AT to an '01MT
Old Dec 6, 2002 | 11:45 PM
Juker008's Avatar
TRELOS
Is it possible to convert a '01 auto to an MT. I do believe that the MT conversion would work but I am questioning if it is possible to add the additional motor mount.
Anyone know?
Juker008
Old Dec 7, 2002 | 12:21 AM
scalbert's Avatar
Possible, yes...
But it would be more economical to take a hit on an auto for a manual trade.
Old Dec 7, 2002 | 12:31 AM
I am RobG's Avatar
im back
anything is possible for the right amount of $$$
Old Dec 7, 2002 | 01:50 AM
Juker008's Avatar
TRELOS
Originally posted by scalbert
Possible, yes...
$15K hit vs. a $2K conversion. I thought of doing a trade in but came up with the conversion for a solution.
Question, is there a place/bracket/perch to mount the additional engine mount?
Juker008
Old Dec 7, 2002 | 01:52 AM
haiduc's Avatar
Moderator Alumnus
maybe that, but you also have to worry about the master cylinder, cables, reservoirs, lines...... ecu?
i think its too much to worry about IMO.
Old Dec 7, 2002 | 02:37 AM
mt6forlife's Avatar
Who says you can convert for only $2,000?
Old Dec 7, 2002 | 03:30 AM
Juker008's Avatar
TRELOS
It was really just a guess-ta-mate. I mean really how much is a gear box and extra pedal?
Juker008
Old Dec 7, 2002 | 04:40 AM
typeR's Avatar
id guess more than 2000K plus new ECU...
Old Dec 7, 2002 | 05:34 AM
allmotor_2000's Avatar
The '03 ECU controls a few things with the tranny. You need the clutch fork, pedal, master-cylinder assembly, slave-cylinder assembly, clutch-lines, axles, four new motor-mounts (I think), interior center console (bottom-part), shift-cables, shifter, and don't forget the knob!
I had to run a hard clutch-line once on a civic while the engine is in the car... not fun!! Most of the conversions I have seen use steel-braided lines.
In any case... you have to consider the fact that the '01 and '02 CL-S were designed without a Manual Transmission in mind. It appears the MT was an after-though. So, a lot of the stupid little holes and plugs and things on the chassis, frame etc. might not be present in the older vehicles. I'd think an '03 would be slightly easier to convert!!
Old Dec 7, 2002 | 08:12 AM
scalbert's Avatar
I would guess that the cost would be in the $5000+ range. You could probably trade in and take about that much of a hit and have a warranty for the 6-Speed...
Old Dec 7, 2002 | 08:40 AM
moforose3.0's Avatar
What can I get ya?
If I were you I would just trade it in and get a newer one and take the negative equity. Its a pain in the ass to do the swap and you never know if somethings going to go wrong. I would just get the 03'w/ warranty if you are that much about it. It should cost around 5k to do the swap, I know Ive been doing alot of research.
Old Dec 7, 2002 | 10:53 AM
mc222's Avatar
I hate the Mets
Well-Are you "in" with any Acura dealer? Blow the auto tranny, take it to Acura and tell them you'll pay the difference
Old Dec 7, 2002 | 01:24 PM
Juker008's Avatar
TRELOS
Re: ...
Thats a thought. Although I feel that if the cost is 5K to do the conversion then Acura would tack on an additional 2K (cost of new tranny) so they don't have to shell out anything.
Juker008
Old Dec 7, 2002 | 09:53 PM
JasonT's Avatar
Possiable. But it's alot harder to convert a car that never had a manual option. Tons more work. Parts alone would be in the thousands. Then there's labor. $5-10K project 3 or more weeks to do. Makes no sense to me. Makes better sense to trade in the car, if not for a 6 speed, then for a totaly different car.
Old Dec 7, 2002 | 11:40 PM
bkknight369's Avatar
plus, wont doing this like completly void your warrenty?
Old Dec 8, 2002 | 12:44 AM
Juker008's Avatar
TRELOS
Thinking of the future, doing this after 100K, see .
Juker008
Old Dec 8, 2002 | 12:46 AM
Juker008's Avatar
TRELOS
Agree. But it would be a $13K-$15K kick in the balls if I did a trade off. So $5K to do a conversion seems a whole lot better.
Juker008
Old Dec 8, 2002 | 12:53 AM
Shawn S's Avatar
Re: Converting a '01AT to an '01MT
I did and had them paint the car BLUE when they were done swapping the Tranny.
BTW….. J/K
Shawn S
Old Apr 9, 2004 | 03:54 AM
typeSb00st's Avatar
has anyone done this swap on a 01-02 cl yet? are the mounting points there for the necessay swap?
Old Apr 9, 2004 | 05:44 AM
AK_MOBBER's Avatar
VOTE OUT THE BUSH REGIME
as I remember someone did this kind of a swap on an accord...
they swapped the whole engine 3.2 litre type s including the 5 speed manumatic slush box (teh shit tranny)...
I supposidly costed $8 K to do the whole conversion.
Fortunatly it didn't take much custom work because most of the CL/TL peices bolted right up....
I dunno how this would work with a 6 speed...
Try searching for the thread or someone can pull it out of their favorites... Good luck!
Old Apr 9, 2004 | 09:44 AM
G's Avatar
G
Bitten.
You could definetly do it, but, the parts cost would be the least of your worries. The ECU is the biggest problem. The amount of work it would take just to make the ECU compatable with the MT would be thousands. I would say just bite the bullet and trade-it is not worth the endless hours of work and money for the swap.
Old Apr 9, 2004 | 10:34 AM
bryanz3.0cl's Avatar
nothing
if it was a direct bolt up on a j30 why wouldnt it work with a j32?
Old Apr 9, 2004 | 10:45 AM
mykemcnasty2's Avatar
I've been having similar thoughts, because after 100k it would def be worth it for the conversion, but trading in may be the better option. It's just that all that stuff has been applied to your car and it would be nice for a cheap tranny swap. keep up the good research as I'll be following this thread closely......
Old Apr 9, 2004 | 10:48 AM
Teh Jatt's Avatar
The Oracle of Acurazine!
I dont know about CL but on camry and civic, it can be done for around 800-1000 dollars.... had a friend who did it on camry... for 900dollars... and a friend on civic for 800dollars.
Old Apr 9, 2004 | 10:54 AM
wakeboardfusion's Avatar
Miss th 3.0
i would like to see if it can be done
Old Apr 9, 2004 | 11:07 AM
Bulldog01's Avatar
Masshole
I know these costs would be minimal compared to others, but would he have to change the radiator, thermostat, and other cooling things, as well? VSA implications?
Old Apr 9, 2004 | 03:27 PM
jriga's Avatar
Juker008
Just gotta add - if you do the manual conversion : you not only have the cost of the parts and labor and maintenance... but when you finally DO go to trade it in, it'll be worth about $1000 less...
Manny trannys are just worth less than autos for used cars...
Old Apr 9, 2004 | 04:22 PM
darrinb's Avatar
///M POWER
brought back from the dead
Old Apr 9, 2004 | 04:23 PM
Chaptorial's Avatar
Definitely more trouble then its worth.
Is it possible to swap a 6speed for an Auto tranny?
Old Apr 9, 2004 | 05:02 PM
pimpscls's Avatar
THE SILVER BULLET
not worth it man, juss get an 6speeder, i thought of this too, but not economical
Old Apr 10, 2004 | 12:33 AM
Doom878's Avatar
I heard that Rick Case Honda will do the Accord tranny swap so I wonder if Rick Case Acura will do the CL/TL swap. They local for us, juker.
Old Apr 10, 2004 | 01:09 AM
typeSb00st's Avatar
i've talked to the guy with the accord, and he was able to trick the ecu to think its always in D1.
trading the car in now isnt going to be worth it, given that the cl is out of production. but the swap of course, will come later whne the tranny blows after warranty.
a tranny swap is a PITA. its also even worse when no one else has done it, so its like taking a stab in the dark.
Old Apr 10, 2004 | 01:27 AM
Chopsie's Avatar
Beware of leakage
and we're talking 2002 here.
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
hpfiend
Sep 27, 2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
Sep 25, 2015 10:34 AM
ivegotthenav
Sep 11, 2015 07:51 PM
alan_rich
Sep 7, 2015 11:08 PM
