Clutch is soft
Old Jul 1, 2007 | 04:00 AM
LIPPSTUH's Avatar
Unregistered user
Clutch is soft
The clutch pedal has been getting softer and softer in the past 2-3 months. i checked the fluid and it's full. is there a way to make it more firm. its SO SOFT!
Old Jul 1, 2007 | 05:09 AM
ll1l2l1l2lll's Avatar
w202 on carlssons
you should let me drive it and feel it. you didn't say anything about it today -___-"
Old Jul 2, 2007 | 12:57 AM
LIPPSTUH's Avatar
Unregistered user
psh no donald
Old Jul 2, 2007 | 03:05 AM
Allout's Avatar
Blown is Best
S/B self adjusting.
Old Jul 2, 2007 | 11:00 AM
LIPPSTUH's Avatar
Unregistered user
s/b? please explain.
Old Jul 2, 2007 | 02:11 PM
SIRSIG's Avatar
THE J35A2...
mine is not...
Old Jul 2, 2007 | 04:51 PM
All Mine's Avatar
I'm a Vagiterian.
Mine's real soft for some reason. It's also notchy. It clicks every couple millimeters as I push it in.
Old Jul 2, 2007 | 04:54 PM
fsttyms1's Avatar
You could try re-bleeding the system
Old Jul 3, 2007 | 03:19 AM
LIPPSTUH's Avatar
Unregistered user
any DIY? i'll try that and get back to you. mine is not notchy.
Old Jul 3, 2007 | 10:02 AM
fsttyms1's Avatar
I dont know if there is a DIY here or not, but its just like bleeding a brake. Attach a hose to the slave cyl and have some one assist by pushing in on the clutch. also making sure that the clutch reservoir doesnt go empty
Old Jul 6, 2007 | 04:51 AM
LIPPSTUH's Avatar
Unregistered user
i looked into a few DIY/tutorials. looks simple... kinda.
but the thing is, there has been and still is full fluids in there, so i don't understand why there could be air... could it be something else?
Old Jul 6, 2007 | 08:02 AM
Moodist's Avatar
One of my other cars is a M/T, the clutch started to get real soft. A month later it started slipping 3rd and 4th gear. How many miles do you have on your clutch?
Old Jul 6, 2007 | 10:53 AM
LIPPSTUH's Avatar
Unregistered user
33,000
Old Jul 6, 2007 | 02:52 PM
Moodist's Avatar
Hmm...33k is not much. I get the car back today, I will tell you what he says about
the clutch being soft. Today the mecahnic said in addition to the clutch, he needed
to replace some seal.
Old Jul 7, 2007 | 12:43 AM
LIPPSTUH's Avatar
Unregistered user
ok thanks! hope to hear from you soon. ask him what can make the clutch soft. i checked my clutch fluid, its still there... dark though... but there.
Old Jul 12, 2007 | 11:17 AM
LIPPSTUH's Avatar
Unregistered user
i just saw in the BM someone replaced their clutch at 52k.... wow.
what's the average life of our clutch?
Old Jul 12, 2007 | 03:00 PM
Allout's Avatar
Blown is Best
It really depends on how it's driven. I think others have put over 100K on the original clutch.
Old Jul 13, 2007 | 08:51 AM
Moodist's Avatar
Lippstuh - The mechanic didn't rebleed the system, the clutch and the pressure plate were replaced. Also the flywheel was resurfaced (this cannot be done for the cl dual mass flywheel). Also the rear engine seal was replaced, a little bit of oil was falling on the clutch.
Did you buy your car used? Since you only have 33k, take it to the dealer, see what they have to say. The clutch fluid shouldn't be dark, it is usually golden brownish. I don't see why it would get dark anyways.
Old Jul 13, 2007 | 10:12 AM
GreenMonster's Avatar
Ryan, I hate to have to remind you, but you don't have a 6spd... you still have a 01 5at CLS remember ??
Old Sep 19, 2007 | 11:45 AM
LIPPSTUH's Avatar
Unregistered user
will i be covered under warrenty?
last time i brought my car in for the srs they billed me assholes...
Old Sep 19, 2007 | 05:21 PM
For a Clutch ?? No... it's a normal wear and tear item like tires and brakes...
I've got 65K on mine, and it's not what it used to be, so I expect to have to replace it before 100K...
Old Sep 19, 2007 | 05:48 PM
SuperTrooper169's Avatar
In the Mid-South meow
Could it be something as simple as the clutch pedal spring being stretched out over the countless times you press and release it? Just a wild guess.
Old Sep 19, 2007 | 07:13 PM
LIPPSTUH's Avatar
Unregistered user
its a spring? i really don't want to bring it to the stealership... esp when it's not under warrenty. i guess i'll rebleed the system, probably reinstall the cdd.
i always thought it was more of pressure that makes it stiff. while bleeding the system there is no pressure. you just press it and it's stuck on the floor.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
