Clutch fluid change on a 2003 cls
Old 05-01-2015, 11:28 AM
chunky's Avatar
Original owner of a 2003 CLS I have never changed my clutch fluid and the color is still a very nice light amber. I am also on the original clutch with 214,000 KM'S Question is, should I leave it alone or should I have the fluid changed?
Old 05-01-2015, 11:40 AM
3.5 psi
gnuts's Avatar
change it. It's a pretty easy DIY. Make sure the car is as level as possible.
Remove drain bolt, drain, put bolt back on.
remove small overfill bolt.
Fill from above until fluid comes out of overfill bolt.
when fluid stop coming out, put overfill bolt back on.
Put filler bolt back on, done.
chunky (05-01-2015)
Old 05-01-2015, 12:56 PM
chunky's Avatar
Thanks for your instructions. How much Honda brake fluid should be bought? do you know? Much appreciated!
Old 05-01-2015, 12:58 PM
Received 16,260 Likes on 11,971 Posts
i think gnuts confused the transmission fluid for the clutch fluid.
he gave instructions on how to change the transmission fluid
to change the clutch fluid, you would bleed it like you would bleed brakes.
attach hose to slave cylinder, then pump clutch till you see clear fluid at the hose in slave cylinder, while keeping eye on master cylinder reservoir
The following 2 users liked this post by justnspace:
chunky (05-04-2015), gnuts (05-01-2015)
Old 05-01-2015, 02:21 PM
3.5 psi
gnuts's Avatar
my bad I read that too fast. thanks Justin!
Old 05-04-2015, 06:04 AM
chunky's Avatar
Thanks for catching that. Is it worth doing? The fluid still looks brand new...
I change my brake fluid every three years but never did the clutch fluid
Old 05-04-2015, 06:49 AM
brake fluid is hygroscopic; meaning it absorbs water from the atmosphere.
it could possibly form rust from inside the lines.
if you have a full day of DIY's, I would add it to the list.
Old 05-04-2015, 06:50 AM
and not to sure if DIY bleeding clutch is like my bleeding of clutch on my 3G TL
I needed a 2nd person, or a block of wood to keep the fork from moving.
chunky (05-04-2015)
mada51589
05-03-2022 08:54 PM
cobra10363
01-16-2021 08:12 PM
mugen_kid
11-13-2015 10:38 PM
nanos
11-12-2015 08:41 PM
Aleax
09-11-2015 11:31 AM
Quick Reply: Clutch fluid change on a 2003 cls
