Check engine light on. STP injector cleaner?
The check engine light came on just yesterday but the car drives normal and there is nothing unusual. The only thing I could think of is the STP injector cleaner that I put in on a full tank. Could it be the issue? Anyone had this happen because of an additive?
Don't Mess With Texas
Originally Posted by Lord Helmet
I just went thru a bottle of Lucas and it was fine. The car runs better too.
i might have to try that stuff.
make sure your gascap is on tight cause that effects your codes.
go to a local autozone and have them check the code for free, that way you can find out if its something serious in less than 5 min.
Originally Posted by cltypeSLOW
what did you get ?
PS. if it is the gas cap... does the light need to be reset or it will go away on it's own?
HeloDown
09-08-2015 06:51 PM
