check engine light
Originally Posted by RaviNJCLs
Take it to Autozone and have them scan it. They do it for free. And if it's something serious, take it to the dealership.
If the question would have been about the maintenance required light, we could have told you how to shut that off (it's a sticky in the FAQ forum).
Former Sponsor
Originally Posted by jctzin
what is the best way to turn the check engine light off. my car has about 100k just turn on recently thanks
J/k... go to Autozone or Advance Auto. They will usually scan the code for free. Then respond with what the code # is what it is desribed as. More than likely it is probably an oxygen sensor code or misfire code b/c you are due to replace spark plugs and sensors right about now.
I think i know why the check engine light comes on because I didn't put the gas cap back on after i finish pumping gas for a couple of days .....damn....... oh well I will go to autozone to see if my car do need a spark parks change
Excelerate,
how much do the oxygen sensor cost anyway to replace I know the spark plugs doesn't cost that much...... I just read the manual yesterday and looking at adding oil for brake, power steering etc...... Manual stated that I should use honda oil only I am assuming that is not the case right.....
Former Sponsor
Excelerate,
Originally Posted by Excelerate
I believe the only stipulation on the brake fluid is DOT 4 brake fluid. It will say it on the cap of the brake fluid reservoir what you need to run. Power Steering fluid can be any power steering fluid, although obviously Honda's fluids are made specifically for Hondas. The stock spark plugs are double platinums and will cost you probably about $18 each from the dealer. I can get you some NGK or DENSO Iridiums if you want.
Not Asian
Originally Posted by louisn
I respectfully disagree and would use only Honda fluid for tranny, brakes, and power steering. I think they are required in the manual and subs can only be used in an emergency and should be replaced ASAP.
Received 1,080 Likes
Where should I only use Honda fluids?
Transmission - Honda ATF-Z1
Power Steering
Where can I use other brand fluids?
Engine oil
Brake fluid
Blinker fluid
Power Steering
Engine oil
Brake fluid
Blinker fluid
Not Asian
Originally Posted by CLSDefiant
yea my check engine light came on and its my torque converter, so i am buying a warranty and gunna drive it till it drops then get it fixed by warranty.
Acura loyal for 93mo/109k
Power Steering
Engine oil
Brake fluid
Blinker fluid
Power Steering
Engine oil
Brake fluid
Blinker fluid
http://www.geocities.com/changeyourblinkerfluid/
MP90 uninstalled
hey, hey...,
six speeders should use redline fully synthetic MTL. It is for hondas and makes a noticable improvment the second you put it in. wish i knew about it a long time ago.
Originally Posted by phipark
how many miles to you have on your CL? If the check engine light came on, you can get it replaced right now if you have under 100k miles.
I got a warranty so il wait 90 days and 1000 miles and they will replace my tranny...hopefully.
not to hijack. The other night I put my car in reverse and backed up. When I put it in D5 it wouldn't go. It felt like I was trying to drive over a cinder block. D5 light started flashing. Check engine light came on, I thought F#@k my tranny just went out at 2000 miles out of warranty.
mfather is a transmission man. He took it to his shop and somehow two wires got broken of at a connector. Anyways check engine light is still on and I would like to know if I can shut it off myself. Also he said no other codes came up as far as the tranny was concerned but he did not go any deeper to look around. Kind of a quick fix I guess. So any one know how to shut it off?
HeloDown
09-08-2015 06:51 PM
