Check Engine Light
Old Dec 9, 2003 | 08:23 AM
RandyMax's Avatar
Check Engine Light
Check engine light came on yesterday...
Is there a way to find out what code it threw without a code-reader? I don't have one, and I hate to pay the dealer $80 to reset the light if it's just a loose gas cap...
Old Dec 9, 2003 | 08:41 AM
KavexTrax's Avatar
umm someone here mentioned that an autoparts store could read it for you, so you'd buy their parts heh.
Old Dec 9, 2003 | 08:57 AM
tmk70's Avatar
Masshole
Sometimes it comes up at certain mileages...just reset it, it's in the manual.
Old Dec 9, 2003 | 09:38 AM
Bluto's Avatar
Find beauty in dissonance
If it is the gas cap, it will reset itself. I think mine took 2 or 3 tanks.
Old Dec 9, 2003 | 11:32 AM
rondog's Avatar
Former Sponsor
no mods huh.
Old Dec 9, 2003 | 01:06 PM
RandyMax's Avatar
Autozone used to do this for free, but then they killed the program a while back. They are being sued by the manufacturers of those code readers I heard.
tmk: I need to check the manual again. I remember there are instructions to reset the "maintenance required" light, but I didn't recall there are instructions to reset "check engine" like. I think we need those code reader to do so, but I may be wrong.
I used to be able to grab DTCs and reset check engine light for my Maxima without using any code reader. That's a really cool feature.
Old Dec 9, 2003 | 01:21 PM
CO-CL-S's Avatar
That's the maintenance light.
Old Dec 9, 2003 | 01:53 PM
trippnup2's Avatar
5th Gear
sooo does
Anyone know how to reset the maintainence light? (shameless hijack)
Old Dec 9, 2003 | 03:24 PM
SFLA_Type-S's Avatar
Sold 12/29/04 :-(
Re: Check Engine Light
Why would they charge you. Shouldn't that be covered under warranty?
Old Dec 9, 2003 | 03:36 PM
RandyMax's Avatar
55557 miles...
even if you are under warranty, if it turns out to be a loose gas cap, the dealer can charge you to reset it --- user error.
Old Dec 9, 2003 | 06:28 PM
Sold 12/29/04 :-(
Wow, that sucks.
Old Dec 9, 2003 | 07:13 PM
ChadT's Avatar
Spectacular Aroma About
Re: sooo does
If I recall correctly you.... 1) turn the key off 2) hold the trip odometer set and select buttons both down 3) while holding the set+select buttons turn the key on and keep holding the buttons until the light resets.
Old Dec 10, 2003 | 09:30 AM
RandyMax's Avatar
The light turned off by itself. Must be a loose gas cap?
Old Dec 10, 2003 | 11:38 AM
Jens H.'s Avatar
retired
If your vehicle has an intermittent problem or the problem does not reoccur the MIL light (malfuncton indicator lamp also known as check engine light) will turn itself off .the code is stored untill the ecu is told to erase it or the battery is disconnected .There is no manual provision for code reading on these vehicles .
Jens
Old Dec 11, 2003 | 06:31 PM
sgmotoring's Avatar
Bleed Honda Blue
manually unplug your ecu for about 20 sec. It is located between the center console. You have to unplug all 4 plugs on the right side of the ecu.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
