changing brake fluid
it's supposed to be done at 45k
first what you do is drain all the fluid out of the master cylinder...i use an old turkey baster and suck it out...then fill it w/ new fluid. Then bleed the brakes about 10x per wheel and it will draw out the old fluid in the lines and replace it w/ the new fluid in the master cylinder...just remember to keep adding fluid into the master while bleeding....good luck
This makes it real easy. If you get some Super Blue brake fluid you can tell when you have all the old stuff out of the system.
http://www.motiveproducts.com/
is it necessary to follow a certain bleeding order like in this thread?
http://www.acura-cl.com/forums/showthread.php?t=182598
dude I just paid $80 CDN for the brake fluid change at the local Acura dealer. That's not much, I would suggest not to mess around with your brakes if you've never done it before.
mada51589
05-03-2022 08:54 PM
ulrblitzer
09-24-2015 07:42 PM
