Catalytic Converter Replacement Pipe for CL-S?
A friend of mine replaced the Catalytic Converter on his RSX with a "test pipe" Accoriding to him, he got an increase of 10 hp. I looked at www.testpipes.com and they don't have a "test pipe" for the 2003 CL-S.
I understand that if you replace the Cat, you won't pass smog. However, I've been told, its a simiple installation and if you can't do it yourseld, it costs about $30 bucks at a muffler shop.
Has anybody heard about replacing your Catalytic Converter for increased power? If so, does anybody know where you can buy one for an 03 CL-S? Also Pros and Cons? Thanks.
Yeah but the other prob is that your ecu will light up like a chritmas tree from the secondary o2 sensor........ Theres lotsa of these pipes arounf the work better on some cars then others.. the "better" ones are a bypass diverter so you can manually select thru-cat or bypass cat.. And a custom job shoulndt cost more then $100
Originally posted by TheModMole
Shawn,
It does decrease torque quite a bit from the lack of back pressure.. it also retards timing .. but thats a whole other long story......
Shawn,
I'd like to hear your explanation on how it retards timing.
Removing the cat will increase hp. The RSX is an unique car because putting an intake, removing the cat and tweaking the ECU (Hondata) puts about 40hp at the wheels!!!! That configuration puts about 205hp at the wheels on a motor that's rated at 200 crank hp stock!
Oh yeah... if you plug in the second O2 sensor to the test-pipe, you won't have a check-engine light. The problem is that your fuel-maps will change slightly and you have to compensate for that somehoe either with a V-AFC controller or something like that.
Yup that may work aside from the fact that youll be running rich as all hell
And then to use a vafc to try and lean the mixture without direct control over spark advance would make for one hell of a mess....... better off just wiring a quarter watt - megaohm resistor inline with the ground on the sensor.....
Florida and Hawaii are the only states that dont require emission testing but I *THINK* a federal fine of $1500 still applies somehow.... Not sure how that would be enforced in states that dont require emission testing though lol all you guys in C.A. are out of your fucking minds to even try it lol thats why I wont even consider moving there with the CARB gustappo
Yeah, the fines are a bitch! I would be worried if I was driving a Civic Hatchback or Integra. But a CL! What cop is going to look under the car on a luxury coupe with stock rims??!! I dunno, just thinking about it. I think I'll go with headers instead...
cycdaniel
Dec 17, 2019 10:58 AM
orkoTL
4G TL Problems & Fixes
107
Sep 28, 2017 09:12 AM
BlkTxAcuraTypeS
Oct 18, 2015 08:05 PM
IIDXholic
Oct 8, 2015 07:53 AM
