Bumper Removal, 3 screws....
Advance
I cant get these stupid fucking screws off im so pissed I tryed spraying them with PB Blaster and using a impact screwdriver wtf they are fucking welded on or something? what can I do?!?!
whoa are you talking about those 3 large flat headed screws at the front of the bumper? if so then those are like a #3 phillips screwdriver tip. find the largest tip you have that will fit snug or you will strip the screws out, like from what i read, has already happened. plus the larger tip will probably be on a larger handle which will give you more grip/turning power.
07 ASM TL
If they are that hard to get out I don't think you are going to be able to drill them out. I think it will mess up the threads. Try putting a slot on the screw with a saw or dremel, and soak the screw in PB Blaster or try using a little heat. And go at it with an impact driver.
Well...it's kinda fast...
If they're that difficult to get out, a screw extraction bit will definitely work. And if you use it properly you shouldn't have to worry about stripping the female threads.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
STL TL-S
09-23-2015 08:52 PM
