brake question....
shift@8k
brake question....
ok so yesterday my friend helped me install my rotora slotted rotors f/r and goodridge brake lines. i have the legend calipers and aem pads ready to install, but left them back home so we put off installing those till later. Install went smooth but as soon as i drove off onto the freeway, any braking past 60mph made my steering wheel shake. I'm pretty sure my rotors are warped, but could it be anything else? Should I wait to see if it still shakes after i install the calipers and aem pads or would that not change a thing? Thanks guys
shift@8k
hmmm i just went back to that thread and read allout's comment on that....i figure since these rotors are warped already there wouldn't be any harm in resurfacing them.
Originally Posted by shinybluecls
ok so yesterday my friend helped me install my rotora slotted rotors f/r and goodridge brake lines......
You're scarin me. About to install Rotora slotteds.
Plus i hope i can turn them problem free after X # of miles.
says "hello to my TLX".
Originally Posted by mc_yanzo
Did you do the break-in procedure properly?
all of you go to the meet. hehe
Adventurist.
Are your pads set in correctly? Meaning are they flat with the piston face?
Also, check to see if you have the rotors flush against the hub. I'm guessing you reused the retainer screw, correct?
Also, try to break-in your new brakes... do a few 80-5, 60-5, 45-5 semi-stops. Don't completely stop as this will lead to your pads sticking to the rotor face.
shift@8k
well thats the thing...i tried to brake in the new brakes but as soon as i tapped the brakes my wheel started shaking. and i'm positive everything's installed correctly....my friend who helped me works for acura.
shift@8k
ok guys new plan...i'm gunna install my calipers and pads this weekend and double check my previous install at the same time. Then I'm going to try and do the break-in procedure again and if it still shakes like mad, i'm going to resurface the rotors. Sound good?
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
