brake question....
Old Jan 31, 2006 | 07:50 PM
shinybluecls's Avatar
shift@8k
brake question....
ok so yesterday my friend helped me install my rotora slotted rotors f/r and goodridge brake lines. i have the legend calipers and aem pads ready to install, but left them back home so we put off installing those till later. Install went smooth but as soon as i drove off onto the freeway, any braking past 60mph made my steering wheel shake. I'm pretty sure my rotors are warped, but could it be anything else? Should I wait to see if it still shakes after i install the calipers and aem pads or would that not change a thing? Thanks guys
Old Jan 31, 2006 | 08:25 PM
CL Platano's Avatar
Tristate ViP Crew
I wouldn't do anything else to you change the rotors, the warped rotors would just ruin your pads quicker
Old Feb 1, 2006 | 12:28 AM
shift@8k
should i try resurfacing the rotors? Does anyone know if there are any issues with resurfacing slotted rotors?
Old Feb 1, 2006 | 12:53 AM
Time For Sleeep's Avatar
That's Racist
Someone mentioned in MrSteve's anti-Hawk-HPS pads thread that re-surfacing could exacerbate warping. Not 100% sure though...
Old Feb 1, 2006 | 12:57 AM
shift@8k
hmmm i just went back to that thread and read allout's comment on that....i figure since these rotors are warped already there wouldn't be any harm in resurfacing them.
Old Feb 1, 2006 | 07:34 AM
NighthawkBlue's Avatar
Originally Posted by shinybluecls
ok so yesterday my friend helped me install my rotora slotted rotors f/r and goodridge brake lines......
new out of the box warped or you are installing used ones?
You're scarin me. About to install Rotora slotteds.
Plus i hope i can turn them problem free after X # of miles.
Old Feb 1, 2006 | 07:48 AM
fuzzy02CLS's Avatar
Did you use new pads or the same ones?
Old Feb 1, 2006 | 08:36 AM
RaviNJCLs's Avatar
Are these new Rotoras? If not, I don't think there is any issue with resurfacing them.
Old Feb 1, 2006 | 10:34 AM
mc_yanzo's Avatar
Masshole
Did you do the break-in procedure properly?
Old Feb 1, 2006 | 10:44 AM
Sun Diego CL-S's Avatar
says "hello to my TLX".
this is probably all they need. a good and easy breaking-in. from the sounds of it though, he just went on to drive normally before going for some brake performance demos.
all of you go to the meet. hehe
Old Feb 1, 2006 | 01:59 PM
NiteQwill's Avatar
Adventurist.
Are your pads set in correctly? Meaning are they flat with the piston face?
Also, check to see if you have the rotors flush against the hub. I'm guessing you reused the retainer screw, correct?
Also, try to break-in your new brakes... do a few 80-5, 60-5, 45-5 semi-stops. Don't completely stop as this will lead to your pads sticking to the rotor face.
Old Feb 1, 2006 | 02:48 PM
shift@8k
well thats the thing...i tried to brake in the new brakes but as soon as i tapped the brakes my wheel started shaking. and i'm positive everything's installed correctly....my friend who helped me works for acura.
Old Feb 1, 2006 | 03:31 PM
shift@8k
ok guys new plan...i'm gunna install my calipers and pads this weekend and double check my previous install at the same time. Then I'm going to try and do the break-in procedure again and if it still shakes like mad, i'm going to resurface the rotors. Sound good?
Old Feb 1, 2006 | 04:34 PM
brianlin87's Avatar
ASM I.S. Design FTW.
Good luck mang.
GWEEDOspeedo
Jan 15, 2016 10:39 PM
lanechanger
Oct 13, 2015 10:56 AM
rockyboy
Oct 2, 2015 10:45 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
