brake problem?
Old Oct 21, 2004 | 09:24 AM
BrutusHayes's Avatar
brake problem?
i recently installed new pads and rotors on my cl-s but had a little problem which caused me some concern..
when i used a clamp to press down on my caliper to make more room for the newer thicker brake pads a slight bit of fluid came out.. my brakes seem to work fine though.. should i be concerned about the little bit of brownish fluid that came out?
also my brake pads were worn very unevenly.. the left rear inside pad was about 25% there where as the outside was completely gone.. and both pads on the right side were down maybe 50% and had a lot more left than the other side..
Old Oct 21, 2004 | 09:45 AM
bigman's Avatar
'Big Daddy Diggler'
yeah, you should be concerned with fluid coming out. Did you bleed your lines and check them to see if there are any leaks. Stopping a 3000+ pound car is not cute when you have no line pressure in your braking system.
Old Oct 21, 2004 | 10:56 AM
fuzzy02CLS's Avatar
Where did the fluid come out? The lines? or the master cylinder?
Old Oct 21, 2004 | 02:21 PM
Jens H.'s Avatar
retired
If the fluid came out of the caliper in the area where the piston is it might be a cause for concern as the seal there may be faulty .It would be highly advised to have a pro look this over as you may suddenly lose brake effectiveness due to fluid leakage .
Jens
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
