Brake Pads and Rotor/Disc
Old Jun 13, 2005 | 01:57 PM
dacura's Avatar
Can someone recommend a place to get brake pads (front and rear) and front rotors for a 2001 CL-S ? I'm only interested in Acura OEM parts. As low priced as possible.
thanks...
Old Jun 13, 2005 | 02:14 PM
andyjl's Avatar
just go with the Rotora cross drilled rotors and satisfied pro ceramic brake pads. They are much better than the shitty oem ones and plus they'll probably be cheaper or equally priced. You can pretty much find the rotoras at 130 - 150 per each pair i believe.
Old Jun 13, 2005 | 02:56 PM
Bobbydoedoe's Avatar
I'm Cool
i also heard alot of good things about the ebc green stuff
Old Jun 14, 2005 | 11:04 AM
russianDude's Avatar
I am very happy with my Brembo blank rotors and Akebano pads. Its cheaper & better than OEM.
Fits perfectly , same specs as OEM.
I'd suggest not to waste money and time with OEM brakes, they are expensive and will warp quick!
Old Jun 14, 2005 | 11:16 AM
anothercls's Avatar
People have said that the Brembo blanks will warp as well, I would suspect it is based on how you use the brakes.
Old Jun 14, 2005 | 11:46 AM
yes, they will warp. But it should take longer than OEM, considering Brembo blanks half price of OEM. I am begining to belive that OEM pads is the main problem for warped rotors. You can buy good after market pads that are "rotor-friendly", which supposed to reduce warping.
Pads that give you good stoping power usually wear out your rotors quicker, thats why I got Akebano, that supposed to be easy on rotors while giving you above average stoping power.
they are also ceramic with very little dust.
Old Jun 14, 2005 | 08:17 PM
Viscous's Avatar
If you check out www.rockauto.com, they have a wide variety of choices (oe style or performance), and the pricing there is pretty reasonable.
Old Jun 16, 2005 | 04:55 PM
NighthawkBlue's Avatar
Carbotech Engineering
http://www.carbotecheng.com/
Owner Larry really knows his stuff on brakes and rotors.
Very good prices.
Old Jun 16, 2005 | 06:17 PM
dshearon's Avatar
just a heads up... i didnt check the cost of other brands but i was able to get my front Rotora drilled and slotted rotors from Horsepowerfreaks.com for $190 shipped thats $20 cheaper than the group buy that is goin on right now
Old Jun 16, 2005 | 06:21 PM
sonnyboyacura's Avatar
2010 SHAWD
and these will fit a stock 03 CLS?
Old Jun 16, 2005 | 07:25 PM
dshearon's Avatar
yes... here is the link
http://www.horsepowerfreaks.com/sale...s/Brake_Rotors
Old Jul 20, 2005 | 02:50 PM
bojangling's Avatar
Do you have to replace both the front and back rotors at the same time?
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
