Brake light on when cold
Old May 14, 2013 | 05:03 PM
cl82793's Avatar
newb here in the forum , recently purchased an 03 CLS.
brake light on dash is on on cold mornings and front cliper grabs when braking. boht gone after car warms up.
what gives? appreciate any insight.
thanks.
Old May 15, 2013 | 10:01 AM
harvthesecond's Avatar
My 03 CLS-6 does that from time to time when really cool out. I think it may be ever so slightly low brake fluid(cool fluid takes less space than warm fluid or flows less or something). After a stop or two the light goes out. The grabbing might just be the rotors getting slightly rusty. I notice that often if I wash my car and park it in the garage for the night. The next morning the brakes will be really grabby as I back out.
Old May 15, 2013 | 11:43 AM
cl82793's Avatar
thanks for the reply. i have read in this forum the float probably is at fault.
Old May 15, 2013 | 12:57 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
The float likes being all the way at the top. Add fluid and it goes away most of the time.
However if u gotlowfluid it's likely cause ur brake pads are on their last legs and therefore u need new pads at a minimum
Old May 17, 2013 | 07:50 PM
aznboi2424's Avatar
Check pads. Also brake fluid needs to be changed every 2 years.
Old May 20, 2013 | 03:34 PM
boostedorbusted's Avatar
Float are bad about sticking in the reservoir lid.
Old May 24, 2013 | 08:31 PM
Rapture's Avatar
Had this happen to me before. It ended up resolving completely by just readjusting the cap/floater. of course it wouldn't hurt to at least look into whether or not the lines need to be bled... which is usually the other cause, afaik.
Old May 25, 2013 | 06:16 PM
Add brake fluid or change out ur pads and rotors us
Old May 25, 2013 | 07:21 PM
Brandon Allen's Avatar
2003 Acura CL-S6
Awesome my light just came on as well, this thread helped a lot. Im going to add brake fluid i hope that works. thanks
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
space_boy
ILX
51
Aug 15, 2017 12:06 PM
theinsvnity
Sep 10, 2015 10:22 PM
