Brake Light
Old Nov 1, 2004 | 09:04 PM
CLSpeedfreak's Avatar
Need more pwr!
Brake Light
Now why would my brake light be coming on like the parking brake is engaged.. Check parking break obviously but the light is still on. Brake fluid level normal and brake system is in working order.Outside of a shortage, what could be the problem?
Thanks,
Steve Mullins
Old Nov 1, 2004 | 09:06 PM
JaredGMS's Avatar
Meat stick
Fluid level may be normal, but you should check your pads....they may be low.
Old Nov 1, 2004 | 11:47 PM
Dan's Avatar
Dan
Confused
May be a bad sensor on the brake fluid cap as mine was.
Old Oct 29, 2005 | 10:58 PM
shmookles's Avatar
Anyone figure this one out? I got the same problem just now... I'm thinking of switching out the brake to see if this fixes it...
-Ed
Old Oct 30, 2005 | 10:49 AM
Sexicarchic's Avatar
I have the same problem....
Old Oct 30, 2005 | 11:27 AM
Type S Zero's Avatar
brake fluid level sensor probably bad
Old Oct 30, 2005 | 01:27 PM
cltypeSLOW's Avatar
Don't Mess With Texas
i have the same prob too i think its the sensor...cause i go in and fiddle with the float on the fluid container and it goes out for a few days.
Old Oct 30, 2005 | 03:49 PM
shmookles's Avatar
I'll check the brake fluid and see if it changes anything...
Old Oct 30, 2005 | 04:04 PM
shill1234's Avatar
It ain't mine.
check the little float in the master cylinder it has atendancy to get stuck down.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Ny1718
Sep 11, 2015 09:21 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
mav888
1G RDX (2007-2012)
Sep 8, 2015 11:49 AM
