Brake fluid for BBK
Old 03-29-2006, 12:54 PM
I'm Cool
Bobbydoedoe's Avatar
Brake fluid for BBK
going to pick up my BBK on sat. I was wondering what kind of fluid do i need? as i have understood, the bbk only comes with 2 steel lines and you need steel lines to use motul 6000 fluids. So since i only get 2 steel lines, should i go with honda brake fluid or the motul? thanks in advance
Old 03-29-2006, 06:01 PM
CleanCL's Avatar
i got Castrol GT. Seems to be working just fine.
Old 03-29-2006, 07:55 PM
highspeedspecialist's Avatar
i got motul with rubber lines in the back...ok so far
Old 03-29-2006, 08:02 PM
03silvertypeS's Avatar
i've got Valvoline synthetic in mine
Old 03-29-2006, 09:47 PM
Blown is Best
Allout's Avatar
Motul 600 here in both cars. Rotora also sells the steel braided rear lines separately. Do yourself a favor and pick those up too since you'll be bleeding the whole system anyways if you use anything but Honda fluid.
Old 03-30-2006, 01:18 AM
Adventurist.
NiteQwill's Avatar
I use Motul DOT 5.1
Yes, pick up the rear lines....
Old 03-30-2006, 04:38 PM
I'm Cool
what is the real world differences of using motul fluid rather than HONDA OEM ones?
Old 03-30-2006, 07:38 PM
6 speed...
tankmonkey's Avatar
motul has a higher wet boiling point than oem. it has a higher dry bp, too, but wet is what really matters.
Old 03-30-2006, 08:47 PM
mrsteve's Avatar
Castrol GT LMA
Old 03-30-2006, 09:11 PM
CleanCL's Avatar
Originally Posted by mrsteve
thats what i use, its good stuff!
Old 03-31-2006, 01:27 PM
boosted is best
NSX-Tuner's Avatar
First off, I think you meant "Motul 600".
If I understand you correctly, you want to add a front BBK and only replace the front brake lines with SS lines. I wouldn't recommend this since the rear brake lines would still be the weak link in the brake system. In addition, you should also replace the rear pads with similar brake material as used on the front BBK.
When I had the CT 13" BBK installed on my CLS 6MT, I also upgraded the rear brakes with crossed-drilled rotors (OEM size), better pads and SS lines. I used "Motul 600".
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
LeVeL
10-18-2015 04:19 PM
lanechanger
10-13-2015 10:56 AM
Quick Reply: Brake fluid for BBK
