BOOST - Something interesting
Old Feb 9, 2005 | 05:04 PM
Seattle Cl-S's Avatar
Blown LS6!!
As I had posted a couple months ago, when I am at WOT through 1st, 2nd, and 3rd, my boost levels off around 8psi. Obviously, that's higher than the pulleys should technically produce. Anyway, for shits and giggles, I plugged my IMRC back in yesterday and did some WOT runs. I noticed the car felt a little quicker, as expected according to previous dynos. No pinging heard . The thing I noticed was the boost maxed out around 6psi, as it is supposed to. Why would boost be greater with the IMRC unplugged? I thought boost was boost...
Old Feb 9, 2005 | 05:33 PM
mrsteve's Avatar
Opening IMRC = larger volume of air can enter intake easier. Less restrictive air flow = less boost. Or something like that.
If you didn't have headers or exhaust you might see more boost. I would suspect the gauge isn't very accurate. Does it stay pegged at 8psi or does it just "spike" at 8psi and then drop back.
Old Feb 9, 2005 | 06:17 PM
Smitty's Avatar
Originally Posted by Seattle Cl-S
As I had posted a couple months ago, when I am at WOT through 1st, 2nd, and 3rd, my boost levels off around 8psi. .
....... you mean it peaks higher than 8?
Old Feb 9, 2005 | 07:32 PM
Blown LS6!!
Sorry, I guess that statement was a little misleading. It peaks at about 8-8.5 psi. I guess the PV=nRT thingy makes sense.
Old Feb 9, 2005 | 07:46 PM
Smitty's Avatar
what is the weather like out there in WA?....
Old Feb 9, 2005 | 08:21 PM
mrsteve's Avatar
Monday I hit a little beyond 7.5 psi.
Although, given my most recent fuel pressure revelation, my faith isn't placed to heavily in these gauges. Even if they were functioning 100%, the boost gauge is only accurate +/- 0.5psi
Old Feb 9, 2005 | 08:41 PM
Allout's Avatar
Blown is Best
That's my understanding also. High boost numbers don't necessarily reflect the amount of power generated. The SC is basically a air pump. The more restriction, the higher the pressure you're going to see upstream of the restriction. Remove the restriction, boost may drop but gain you HP because of the higher air volume/flow.
Old Feb 10, 2005 | 12:24 AM
Blown LS6!!
I think I can FEEL the little added power with the IMRC reconnected but I was definitely hearing that "nails in a can" sound again. I'll unhook it so I don't blow anything up.
Temps in the 40-50's today.
Old Feb 10, 2005 | 02:16 AM
Smitty's Avatar
yep.. i figured it would not be long before you head detonation again....
FYI:... that nails in a can sound only takes 1 good time for your motor to go BOOM.
with cooler temps you will see increased boost levels... Scalbert might comment.
Once a year someone posts that their CL-S runs like a beast when the weather cools off...
Old Feb 10, 2005 | 03:32 PM
Allout's Avatar
Blown is Best
I thought that I read others having more of a "pinging" problem in winter. This would make sense in CA because of the Winter fuel blend that they sell for "Cleaner Air". Probably more volatile for a complete combustion. Not sure if WA does the same.
CL-S progression 01
Jan 26, 2016 04:15 PM
Euro4gen
Dec 12, 2015 03:14 AM
ROWDY621
Sep 30, 2015 03:20 PM
Sarlacc
Console & Computer Gaming
Sep 30, 2015 02:15 PM
MonkeyTrucker
Southeast
Sep 25, 2015 02:48 PM
