BOOST - Something interesting
Blown LS6!!
As I had posted a couple months ago, when I am at WOT through 1st, 2nd, and 3rd, my boost levels off around 8psi. Obviously, that's higher than the pulleys should technically produce. Anyway, for shits and giggles, I plugged my IMRC back in yesterday and did some WOT runs. I noticed the car felt a little quicker, as expected according to previous dynos. No pinging heard . The thing I noticed was the boost maxed out around 6psi, as it is supposed to. Why would boost be greater with the IMRC unplugged? I thought boost was boost...
Opening IMRC = larger volume of air can enter intake easier. Less restrictive air flow = less boost. Or something like that.
If you didn't have headers or exhaust you might see more boost. I would suspect the gauge isn't very accurate. Does it stay pegged at 8psi or does it just "spike" at 8psi and then drop back.
Originally Posted by Seattle Cl-S
As I had posted a couple months ago, when I am at WOT through 1st, 2nd, and 3rd, my boost levels off around 8psi. .
....... you mean it peaks higher than 8?
Blown LS6!!
Sorry, I guess that statement was a little misleading. It peaks at about 8-8.5 psi. I guess the PV=nRT thingy makes sense.
Monday I hit a little beyond 7.5 psi.
Although, given my most recent fuel pressure revelation, my faith isn't placed to heavily in these gauges. Even if they were functioning 100%, the boost gauge is only accurate +/- 0.5psi
Blown is Best
Blown LS6!!
I think I can FEEL the little added power with the IMRC reconnected but I was definitely hearing that "nails in a can" sound again. I'll unhook it so I don't blow anything up.
Temps in the 40-50's today.
yep.. i figured it would not be long before you head detonation again....
FYI:... that nails in a can sound only takes 1 good time for your motor to go BOOM.
with cooler temps you will see increased boost levels... Scalbert might comment.
Once a year someone posts that their CL-S runs like a beast when the weather cools off...
Blown is Best
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
