Blown Motor - Engine Swap Question
Old May 26, 2008 | 11:00 AM
horsepowercrzy18's Avatar
Question Blown Motor - Engine Swap Question
Will a 03 CL-S/TL-S engine that came out of an auto work in an 03 CL-S that had a 6 speed? If so, what would need to be interchanged? All info greatly appreciated. Thanx
Old May 26, 2008 | 11:47 AM
CL-S6's Avatar
Turbo 6 Speed
how did you blow your motor?
TCM 01 CL-S's Avatar
Uses turn signals in my
See posts #16 & 17
https://acurazine.com/forums/technology-16/anybody-have-sony-t616-132270/
Old May 26, 2008 | 11:58 AM
it wasnt me. it was a local friend with a 6 speed
Old May 26, 2008 | 11:59 AM
Originally Posted by TCM 01 CL-S
is that all that needs to be swapped? other than than drivetrain ofcourse
Old May 26, 2008 | 12:13 PM
See post #21 in that thread, I forgot that he added that additional info there.
Old May 26, 2008 | 12:20 PM
ok cool, so basically all the parts he needs, he already has since he can pull it off the old motor, correct?
Old May 26, 2008 | 07:48 PM
CL-S6's Avatar
Turbo 6 Speed
how did he blow the motor? over rev?
Old May 26, 2008 | 08:31 PM
In theory that should work fine as long as those pieces are in tact.
Old May 26, 2008 | 09:26 PM
something like that
ofcourse
Old May 26, 2008 | 09:59 PM
CleanCL's Avatar
imo - at the cost of of buying a junkyard motor, swapping parts, making sure it all works, it's smarter to just tear down and rebuild. you never know what you are getting with a junkyard motor.
Old May 26, 2008 | 11:57 PM
implicit's Avatar
eh
Agreed.... at least that way you're almost getting the equiv of a new motor
Old May 27, 2008 | 01:01 AM
Cocoa's Avatar
2600lb CL
cam sensors and crank positioning sensors are different
Old May 27, 2008 | 08:10 AM
fsttyms1's Avatar
Timing belt crank gear, CKP sensor, front cam gear, the 2 TDC sensors behind the front cam gear, is what needs to be swapped for it to work. Also the engine wire harness is different so you will have to swap yours onto that one.
Old Jun 27, 2008 | 12:00 PM
SCCLS6's Avatar
B A N N E D
Im the one with the blown motor. getting a new motor put in from a TL-S
Old Jun 27, 2008 | 02:13 PM
GrandeInter10's Avatar
Si Vis Pacem, Para Bellum
how the hell did you blow that j32?
Old Jun 27, 2008 | 02:55 PM
CL-S_undance Gold's Avatar
strange he wont tell us how he blew it. i thought they were very strong as im sure the rest of the inquisitors did. i wonder......
Old Jun 27, 2008 | 05:39 PM
blew
blew running high boost pulley with stock injectors and no tune
Old Jun 27, 2008 | 05:51 PM
ChrisQ1980's Avatar
hates the winter
Eeesh
Old Jun 27, 2008 | 07:45 PM
DFoster0's Avatar
why would you do such a thing
Old Jun 27, 2008 | 07:52 PM
Cocoa's Avatar
2600lb CL
Be sure to stick with cold spark plugs with this swap.
Old Jun 27, 2008 | 08:11 PM
Allout's Avatar
Blown is Best
It's not unheard of if you've got high enough octane to fuel the motor.
Old Jun 27, 2008 | 10:06 PM
motor
to run high boost pulley the correct way i would need the greddy emanage tuned and the s2000 440cc injectors.
Old Jun 28, 2008 | 01:23 AM
Allout's Avatar
Blown is Best
Feb 25, 2020 09:57 AM
Allen_442
Sep 8, 2015 06:01 PM
Desert Ridge
Sep 5, 2015 09:47 AM
iRaw
ILX
Sep 5, 2015 12:10 AM
