Big Problems
Old Oct 3, 2006 | 07:57 PM
  #41
withoutcomp1's Avatar
Old Oct 3, 2006 | 08:15 PM
  #42
CleanCL's Avatar
298? 13 flat afr? i duo man, all that money for the emanage/tuning, and i dont think you need it. you could richen up the fuel a bit without spending all that on the emanage. but nice numbers.
Old Oct 3, 2006 | 09:51 PM
  #43
you don't thinke the e-manage and water/methanol injection will do anything for me? The way it's going i am never going to get the e-manage in anyway!
Old Oct 3, 2006 | 10:05 PM
  #44
CleanCL's Avatar
i think it will boost power a bit, but i dont think it's worth the $1,000+ parts. i think you should put that money into something else like ported manifolds.
Old Oct 3, 2006 | 10:23 PM
  #45
ThinJim's Avatar
That's not bad. I'd boost up the fuel pressure and see what that does to your afr. however, it probably would be a little rich while at idle. You should find a fix for the emanage as it is necessary to pull a few degrees timing. I wouldn't go crazy on it as that afr of 13 is a bit lean. stick at it, once you figure it out, that's it, you don't have to do a thing but regular maint.
Old Oct 3, 2006 | 10:41 PM
  #46
maybe not, but screw it i already have everything. Mine as well use it.No if only i can get this e-manage actually working i will be happy. Greddy techs are idiots!
Old Oct 3, 2006 | 10:47 PM
  #47
JBlueCLS6's Avatar
Did you hit almost 300 with the Methanol Injection and a tune?
Did you go to 1320 yet to get it config'd?
Old Oct 3, 2006 | 11:01 PM
  #48
Thats without the e-manage and methanol, like i said the e-manage keeps popping my ign. coil fuse as soon as plug it in and turn the ignition on.
Old Oct 3, 2006 | 11:17 PM
  #49
BigLizard's Avatar
Moderator Alumnus
Originally Posted by withoutcomp1
I like the numbers...I like them a lot. Still can't wait to be up around that neighborhood.
Old Oct 3, 2006 | 11:38 PM
  #50
CleanCL's Avatar
you have the straight plug and play harness from boomslang? you mentioned that originally wired it into ur ignition? also are the proper jumpers set on the emanage. i believe you have to open the unit up to set it up properly before you plug it in.
Old Oct 4, 2006 | 01:11 AM
  #51
chirik's Avatar
withoutcomp1, I don't think you following the important issue that was raised before . No wonder you keep blowing your coils
Originally Posted by 02AV6
And again, remember the following next time you attempt to hook up e-manage:
1. The main unit MUST be setup first with switches and jumpers to work correctly
2. ESM MUST be removed when start tuning e-manage.
Good numbers, though.
Old Oct 4, 2006 | 07:02 AM
  #52
yeah you are right, but then i seen them having problems so i overnighted the full harness. i set all the jumpers and pots to the way either greddy or boomslang told me and it still pops fuses. I asked couple people on the board who have it in there car already to let me know what theirs are set at but nobody can help me.I am going to try and call greddy again today.
Old Oct 4, 2006 | 02:44 PM
  #53
bigguyonbike's Avatar
13.2 @ 104.76mph
you should try to get ahold of scalbert since he was able to set it up correctly.
Old Oct 4, 2006 | 02:57 PM
  #54
Is he still around?
Old Oct 4, 2006 | 08:00 PM
  #55
02AV6's Avatar
563hp daily
I already mentioned you in PM. Take detailed pics of your jumpers and switches, send me e-mail with attachments and I can tell you how to correct them.
As far as Greddy, they're not much help since they don't support J-series and boomslang is a harness fabricator.
Old Oct 4, 2006 | 08:17 PM
  #56
Sent, Please tell me there all wrong and i don't need another e-manage!
Old Oct 4, 2006 | 09:13 PM
  #57
SIRSIG's Avatar
THE J35A2...
Ok i got it, it was a bad coil pack, what a mission i had this morning trying to find one, nobody had one. I finally got it from the napa warehouse in s. plainfield.
i will swap that coil pack from napa asap with the oem, just for the peace of mind...
Old Oct 4, 2006 | 10:14 PM
  #58
It's the same as oem, It manufactured by the same company. The the number and company on the side of both of them were identical.
Old Oct 4, 2006 | 11:30 PM
  #59
SIRSIG's Avatar
THE J35A2...
thought this might help you out a little...
http://www.mohdparts.com/emanage/man...ual/index.html
Old Oct 5, 2006 | 07:00 AM
  #60
Thanks, I have seen that site allready, but thanks anyway.
Old Oct 5, 2006 | 01:59 PM
  #61
02AV6's Avatar
563hp daily
Yep, you've got 3 jumpers and 1 switch set up wrong. I warned you before it's VERY IMPORTANT to set them up correctly before you turn the main unit ON.
Not sure if you need another e-manage, but you should not blow coils from now on. Check your e-mail with correct settings.
1. Hook up first.
2. Fire up the software (v. 1.13 is what I use along with v. 1.39 firmware upgrade)
3. Load the map file
4. Set up TPS calibration (your shop should know how). It's imperative that TPS (throttle position) is done before you fire up your car.
5. Run the car for 5-8 min (do not drive) and check REAL TIME data whether you can see Throttle position, RPM, etc. values. There are check boxes (under REAL TIME) need to be checked to view all settings.
6. Remove ESM
7. Tune e-manage on dyno
You can read the basic instructions (see above links)
Let me know if you need detailed.
That's it.
Old Oct 5, 2006 | 02:26 PM
  #62
02AV6's Avatar
563hp daily
Also, after step 4 above and let's call it 4b you need to EXPORT file back to the main unit. Turn the unit OFF then fire up the car.
Old Oct 5, 2006 | 02:37 PM
  #63
SIRSIG's Avatar
THE J35A2...
does e-manage jumpers and switches set-up same for all of 6 speeders with or without FI? if so, Thinjim can probably help us since he got a 6 speed...
cycdaniel
Dec 17, 2019 10:58 AM
Aug 15, 2019 12:58 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Junior Noboa
Sep 21, 2015 06:28 PM
brandnewcolony
Sep 12, 2015 10:39 AM
