Beware!! Bad AW Header Install Experience
Old Dec 24, 2004 | 10:11 PM
allmotor_2000's Avatar
Folks.
Bobbydoedoe came over to install his AW headers. Nice guy with a beautiful 2003 Blue color CL-S.
The removal went off very smoothly, but the install was a nightmare. Several problems:
1. The O2 bung is positioned incorrectly, so when you bolt the A-pipe upto the manifold, the O2 sensor hits the block - the top part is now bent somewhat.
2. The rear portion of the A-pipe that bolts upto the rear manifold is not aligned with the manifold, hence even with the O-ring seal, it has a slight leak. I broke a Mil-std bolt tightening it... obviously I can't bend the steel flange! It's theta (angle with the manifold) is okay... the two planes are not parallel, if you can picture it - usually the O-ring will accomodate slight variations, but this is pretty bad.
Anyways, in the end we decided Bobbydoedoe can bear the slight leak until Monday where I have arranged for him to go to a shop to remove the A-pipe and reposition the O2 sensor while re-aligning (this means chopping and re-welding) the rear-upper portion of the A-pipe. Re-installing the stock manifold is a pain and then he would have to pay to have the entire thing re-installed when it is cut and welded!
So, bottom line, Bobbydoedoe has to spend another $100 to $150 to fix the darn thing - I feel bad for him, but its a lesson learned.
I have installed a set of AW headers previously and they were fine - its an example of poor quality control in my opinion.
Old Dec 24, 2004 | 10:19 PM
WILLDOGS's Avatar
I shave my change purse
damn
Old Dec 24, 2004 | 10:46 PM
Chopsie's Avatar
Beware of leakage
Sounds like the ever so popular OBX problems
Old Dec 24, 2004 | 10:59 PM
rondog's Avatar
Former Sponsor
yeah, my OBX welds are cracked after half a year, and the bung that holds the O2 sensor was positioned the wrong way, touching the oil pan, had to relocate the bung and buy a new O2 sensor. I'm gonna end up getting a set of Comptechs. BTW, does a cracked weld on the headers with an exhaust leak rob me of HP? there is a clear crack, and black sut around it, but no irregular noise. whaddayathing?
Old Dec 24, 2004 | 11:26 PM
SpeedyV6's Avatar
Thanks for the info Allmotor.
Old Dec 24, 2004 | 11:36 PM
Titand19's Avatar
East Coast Boost.!
I'll look out for this if I do any AW headers
Old Dec 24, 2004 | 11:38 PM
Bobbydoedoe's Avatar
I'm Cool
Well the drive home wasn't to bad it’s just really annoying if over 3000rpm, but you feel the gain that’s for sure, and thank you allmotor for installing the headers on a Christmas day. On Monday I will talk to Excelerate04 (the person who organized the group buy) and show him some pictures about the fitment problems and hopefully he will inform the maker of the headers and hopefully they will do something to correct that before the next batch of headers are ship.
Steven
Old Dec 24, 2004 | 11:58 PM
VeeralS05's Avatar
I NEED MONEY!
GOD DAMN IT!!! I just purchased these damn headers for $600, now what the fuck am I going to do?!!! So, what was the main problem the headers werent aligning properly?!!
What do you suggest I do?!
Old Dec 24, 2004 | 11:59 PM
I'm Cool
as allmotor suggested after the install that i goto a muffler shop and have them realign or relocate the o2 sensor and someother thing
Old Dec 25, 2004 | 12:10 AM
VeeralS05's Avatar
I NEED MONEY!
Well I'm planning on installing mine @ a Car & Body Shop...
any tips for them when I ask them to install them...he said he was going to charge $250...I know the people there pretty well...
Old Dec 25, 2004 | 12:21 AM
I'm Cool
hmmm lets see, just tel him about the known issues about this headers, and tell him to be careful of the o2 sensor
Old Dec 25, 2004 | 12:26 AM
VeeralS05's Avatar
I NEED MONEY!
Is there someone who can make a list of what I should tell him?
Cause from what i read from allmotor, there are a shitload of problems...
I PMed Excelerate asking if he could resend me a good pair of headers...but no answer yet...
Thanks, Veeral
Old Dec 25, 2004 | 01:02 AM
Allout's Avatar
Blown is Best
That's what I paid for my used Comptech's.
Sounds like AW has quality control problems. If some have had problems and others have been fine, it tells you that they can't make a consistent product. With that being said, don't expect the exact same problems with your headers. Consider these as potential problems. You may be lucky and have a set that's fine or be worse off and not even be able to hook up the "J" pipe.
As far as asking Excelerate if he could resend you a good pair of headers, that's a tough request unless they've been bolted up or they have identified a consistent error in this batch. Excelerate can only do so much as a reseller. He can't control quality but can speak to the factory on your behalf.
Good Luck.
Old Dec 25, 2004 | 09:48 AM
Chaptorial's Avatar
New or used Comptech's are the way to go.
Old Dec 25, 2004 | 10:42 AM
Chemmech's Avatar
Used
Old Dec 25, 2004 | 11:01 AM
VeeralS05's Avatar
I NEED MONEY!
Soo, Anyone willing to trade my AW Headers for their used Comptech
Now its going to be even harder to sell my AW Headers. I'll be lucky if someone will buy them cause everyone will think they are defective.
Old Dec 25, 2004 | 11:09 AM
Amoeba's Avatar
Best D-Line in the NFL
From: Gainesville, Fl for college, Palm Beach Gardens, Fl at Home
i got one of the early preproduction prices and i guess one of the earlier models, it fit perfectly fine according to the shop who put them on.
Old Dec 25, 2004 | 11:17 AM
The two problems as I stated were:
(i) The O2 bung is off a few degrees and hits the block
(ii) The rear 'J' portion of the 'A' pipe is not a good fit with the rear manifold - the two flanges are not parallel by any means
Bobbydoedoe will get his fixed on Tuesday
Old Dec 25, 2004 | 12:05 PM
VeeralS05's Avatar
I NEED MONEY!
Doesnt the side that says Alpha Werks go on the rear side? (ex. opposite side that the comptech one did)
Old Dec 25, 2004 | 12:07 PM
VeeralS05's Avatar
I NEED MONEY!
Thats wierd...how can the pre production work and not the regular production...usually when something goes wrong they fix it after the preproduction so that way the final piece is better made. Instead they did it completely vice versa...
Old Dec 25, 2004 | 01:15 PM
brianlin87's Avatar
ASM I.S. Design FTW.
lack of attention to quality due to popular demand
Old Dec 25, 2004 | 01:22 PM
BC2G's Avatar
Registered Big Dog
Originally Posted by allmotor_2000
Folks.
i had exactly the same experience and the o ring i got didnt fit.... the mechanic that helped me told me to have them reweld it at another angle but i havent done it yet and everything seems fine
Old Dec 25, 2004 | 01:43 PM
I'm Cool
hey wanna come along with me to get the thing rewelded on monday? pm me
Old Dec 25, 2004 | 03:43 PM
Hurleysurf24's Avatar
if this shit happened to the new set i buoght off ebay im gonig to go nuts
Old Dec 25, 2004 | 04:32 PM
BC2G's Avatar
Registered Big Dog
dont re sell them, they will fit they're just a bitch to get them on there
Old Dec 25, 2004 | 04:33 PM
BC2G's Avatar
Registered Big Dog
gotta work, where u gonna have that done? diamond bar is like an hour easy away from me... otherwise i would be down.
Old Dec 25, 2004 | 05:56 PM
I'm Cool
the place is in montclare, but i give u the updates on what he has done
Old Dec 25, 2004 | 06:07 PM
mrsteve's Avatar
I purchased my Comptechs used for about the cost of new Alpahwerks. I hate to say it.... but "I told you so"
Old Dec 25, 2004 | 06:09 PM
mrsteve's Avatar
Exactly. Then they come on this board and blow smoke up our asses saying our much attention they paid to the detail of the "design" *cough cough comptech clone cough cough*.
Old Dec 25, 2004 | 06:10 PM
whitepearltsx's Avatar
Well i like said before my brother installed his alphawerks headers and had no problems.
Maybe some of them came bad.
Can any one take pictures of the problems?
Old Dec 25, 2004 | 06:14 PM
mrsteve's Avatar
Exactly... just like "some" of the OBX's were bad, "some" of the Stone headers were band, etc., etc....
None of the Comptechs came out bad. I really don't understand why it is so hard for these companies to get it right the first time. There has been a proven product out for years now, it is only a few pipes and a few welds to copy.
Old Dec 25, 2004 | 06:21 PM
[QUOTE=mrsteve]Exactly... just like "some" of the OBX's were bad, "some" of the Stone headers were band, etc., etc....
How do you know Comptech has never had a bad header?
Just because they never posted on the forums, doesnt mean that they never had a bad one.
Old Dec 25, 2004 | 06:25 PM
MQMH_03's Avatar
im scared to installl mine now... oh man i knew i should have bought used comptech's!
Old Dec 25, 2004 | 06:31 PM
MQMH_03's Avatar
i wonder which batch of headers the bad one came from? Bobbydoe..did you get yours from the recent group buy?
Old Dec 25, 2004 | 06:37 PM
car_lost's Avatar
there are more comptech headers out there than there are obx, stone, megan, alphawerks or any other brand out there. i have yet to see a story of comptechs that didnt fit right the first time.
Old Dec 25, 2004 | 07:30 PM
I'm Cool
yeap
Old Dec 25, 2004 | 08:13 PM
mrsteve's Avatar
Old Dec 25, 2004 | 08:15 PM
MQMH_03's Avatar
oh man..now im really kinda scared...veeral505 let us know how your installl goes...
Old Dec 25, 2004 | 08:59 PM
Chief F1 Fan's Avatar
Can u say "ebay?"
Old Dec 25, 2004 | 09:11 PM
Red-CL's Avatar
Doin' da crack shuffle
Do a search.
Even Comptechs had their fair share of problems when they first began. It happens.
What makes a good manufacturer is the fact that they'll continue to test test fit and improve quality control like Comptech obviously did. Jusr my
