Best shock sensors?
Old 11-21-2002 | 01:57 AM
azn5ucka86's Avatar
Best shock sensors?
is there really a difference in what shock sensors to get, chrisbpickering got his from circuit city, the DEI DUAL stage ones, is there much of a difference from the autotoys.com one for 14.50?
Old 11-21-2002 | 02:34 AM
edgalang's Avatar
Purchased: April 28, 2001
Mine is a Bulldog shock sensor...do a search on google and you'll find plenty of references for it.
Here's one...
http://www.truckstuffusa.com/shocsenbybul.html
Old 11-21-2002 | 02:41 AM
SinnedTL's Avatar
Ain't No Other...
I got a Clifford Piezo, Single Stage and it works awesome...
Old 11-21-2002 | 02:48 AM
azn5ucka86's Avatar
what's the difference between dual stage and single stage?
Old 11-21-2002 | 09:26 AM
juniorbean's Avatar
Someone please correct me if I'm wrong....
Single Stage goes off when it senses a shock.
Dual Stage doesn't go off immediately. You can set the sensitivity of the sensor and it sets a threshold. So, if the car is hit, but not that hard.. it will set off a warning chirp. If it's hit hard enough to set off the second level of the sensor, then the alarm sounds.
To answer the original poster.... I bought mine from autotoys.com. It was around $11 and it works great. Not sure who makes it.. but I'm sure you can find it on there....
Old 11-21-2002 | 10:06 AM
oghondaman's Avatar
You can't wire a dual stage sensor without a separate siren.Dual stage sensor would chirp the siren on a 30% less impact as the initial setting and trip the alarm on the full a full impact.But there is no way to wire it,is there?I have a audiovox dual stage and had to wire it as a single stage.
Old 11-21-2002 | 10:09 AM
chikai's Avatar
trying to get a lil V-I
this question may have been asked before, but is it possible to connect two shock sensors to the factory alarm. I'd like to put one near the HIDs and one inside the car.
joeshmoe's Avatar
My Home Planet
Can a shock sensor be wired to the factory alarm? If so, is it easy or should a professional do it.
Old 11-21-2002 | 10:15 AM
juniorbean's Avatar
Supposedly it's easy.. but I had my dad's friend who does stereos do it. Took him 15 min. Check out this link for the directions:
http://www.acura-tl.com/forum/showth...t=shock+sensor
chikai - I wouldn't see why not. I already have one in the front of my car... and i'm having one put in the trunk area too.. so the whole car is protected. I'm pretty sure you can just wire them in parallel or something.....
Old 11-21-2002 | 08:44 PM
NOVAwhiteTypeS's Avatar
http://public.fotki.com/novawhitetyp...ensor_install/
please read. joshmoe i also have pinouts for the 1st gens
and yes u can have two three 10 or 20 sensors connected.
RobbDizzle
10-15-2015 12:16 PM
StevieB1503
ILX
10-08-2015 05:52 AM
Boraxo
1/2G MDX (2001-2013)
09-29-2015 05:35 PM
thegipper
09-28-2015 02:01 PM
hrothgar02
09-28-2015 12:08 PM
