bbk is making loud noises - help?
Old Oct 7, 2006 | 05:35 PM
CleanCL's Avatar
just installed the 2pc front rotora BBK. at first it was very quiet. now when i come to a stop or hit the pedal too hard a very loud 'harmonic tone' or 'whistle' sound occurs. otherwise it brakes fine. it is not like the squeal/screech that a low indicator pad makes. it is much more pronounced and louder. the harder i press the pedal the louder the sound gets. and it is generally only when coming to a stop less than 10 mph. help?
Old Oct 7, 2006 | 05:58 PM
TOPHER33884's Avatar
Does it kinda sound like High MOANING SOUND, like metal to metal? Because I just bought some new Rotora rotors & pads, and just before my car stops, I get this DRY metal to metal rubbing sound, then a sqeeke!
Old Oct 7, 2006 | 06:03 PM
CleanCL's Avatar
um not really, its dead silent, until right before the car stops it gets a loud whistle noise that increases as the car gets slow. if i let off thebrake pedal and just roll and apply the brake it does it too. but if im doing 60 and lightly brake to 30 or so its quiet. it's really annoying.
Old Oct 7, 2006 | 08:10 PM
CleanCL's Avatar
retorqued all 4 caliper bolts to 79.6
retorqued brake line bolt to 14
all lugnuts torqued to 80
still makes the sound, are these pads THAT aggressive in compound?
who has the 2 pc kit?
Old Oct 7, 2006 | 09:25 PM
PureSound15's Avatar
Every car that I have had a BBK on made noise. From more of a humming sound (usually from the pad traveling over the holes) to a squeek. I have no experience with the kit you have, but I have experienced similar sounds from Brembo GT kits on 2 seperate cars, and also a Bear kit on another car.
Old Oct 7, 2006 | 09:36 PM
CleanCL's Avatar
but the sound will go away right? cause its annoying as hell.
Old Oct 8, 2006 | 01:22 PM
Excelerate's Avatar
Former Sponsor
The pads are a high performance pad. The pads that come with the kit are street/sport pads. Sometimes when the rotors/pads are breaking in they will make some noise; it should go away once everything has broken in. Also did you make sure the dust shield isn't hitting anything?
Old Oct 8, 2006 | 01:35 PM
Titand19's Avatar
East Coast Boost.!
dust shield was removed. The installer of the original bbk bent it so it would not be touching, but we opted to remove it since it really serves no purpose
Old Oct 8, 2006 | 08:02 PM
Bobbydoedoe's Avatar
I'm Cool
Are your rotors slotted? because i think i have that sound too but my friend said it might be the rotors
Old Oct 8, 2006 | 09:27 PM
CleanCL's Avatar
slotted and cross drilled. my first bbk was just slotted and made little to no noise. this is why i'm confused.
Feb 25, 2020 09:57 AM
jblessing
Aug 8, 2018 09:43 PM
yesSIR-S
May 13, 2016 05:42 PM
handsom-hustla
Nov 13, 2015 05:04 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
