Battery Terminals
Old Sep 1, 2002 | 05:54 PM
2Sxy4YoMama's Avatar
Just call me DADDY!!!
Battery Terminals
I found out my battery had the green and white residue. Thus, I was thinking about changing me terminals to copper and instead of getting a new a battery? Will this help the reduce the acid and residue effect? Thanks
Old Sep 2, 2002 | 07:50 PM
anybody?
Old Sep 2, 2002 | 07:54 PM
Klamalama's Avatar
Capo di Tutti Capi
Re: Battery Terminals
Spray some battery terminal cleaner on it to clean it, then protect it with battery terminal protector spray (or cover the terminal judiciously with grease).
Chinisimo's Avatar
pour some carbonated water or soda over it. it'll clean out the green stuff.
Old Sep 2, 2002 | 10:14 PM
Copper Terminals
Thanks the info guys...but my main question is the copper terminals. Should I change them to the copper terminals?
Old Sep 2, 2002 | 11:36 PM
soopa's Avatar
The Creator
i cant imagine copper would be better?!?
think about it... copper turns green when it gets wet.
Old Sep 3, 2002 | 02:42 AM
FDao's Avatar
Re: Copper Terminals
I would go with Klamalama said. It works quite well.
Old Sep 3, 2002 | 03:07 AM
1SICKLEX's Avatar
Use some WD-40 to clean the terminals. It is a great idea to clean em every oil change or so....
Old Jan 28, 2008 | 12:51 AM
johnnyblaz3's Avatar
wd 40 would clean it just by spraying on it?? wouldnt u have to unclip the wires and clean them to??? i have the same problem and thinkin about replacing batter and terminal since it comes from the battery... isnt that why it builds up cuz the battery is leaking acid a bit???
Old Jan 28, 2008 | 12:52 AM
i also read some where that you need to put silicone on the battery when replacing a new battery from avoiding battery acid leak/fluffy corosion?? im thinking about trying it and cleaning the wires a bit... my cars been dieing and i think this problem being fixed would be better
Old Jan 28, 2008 | 09:54 AM
GreenMonster's Avatar
Johhny, this is a 6 year old thread...
Jul 16, 2017 07:33 AM
MetalGearTypeS
Aug 29, 2016 08:28 PM
jdmaszfcuk
Oct 19, 2015 12:31 AM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
