Battery Dying at 56K Miles??
2003 CL-S 6sp
Hey all - quesition about life of '03 battery. Mine seems to be getting low, and I don't know if it's the battery or possibly alternator which isn't charging. I've had to get it jumped twice (thankfully both times I was at a gas station getting gas)
I did recently put in a 300W sub amp, but I am cautious about running the radio when the car is off.
Might this be time for a new battery, or may I need to take a look at soemthing else? Way to test alternator?
Thanks!
Thanks!
I'm here in spirit...
I think you can go to Autozone or something and they will test it for free. My dealer tests my battery every time I take the car to them. BTW, mine was replaced by the dealer I bought it from in Feb. '05 w/37K on it. It could be going but I think you need to have it tested.
CLS 6MT Navi
Batteries age over time irregardless of mileage or use, hot weather ages them too. Mine had to be replaced at about 2.5 years old with less than 25k miles.
that;s what the dealer told me anyway after they tested it when I had an oil change, had no problems with the battery before that.
![what](https://acurazine.com/forums/images/smilies/what.gif)
CLS 6MT Navi
Dealer also said low use can age the battery faster too. My car had only 7500 miles after the fist year when I bought it. The replacement battery Acura put in, (I think it was an Interstate? is supposed to be a lot better than the stock battery.
2003 CL-S 6sp
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
Originally Posted by JDMj20acL
thats actually exactly when mine went.. now you can go for an OPTIMA!!
1) What is the advantage of the OPTIMA battery
2) A co-worker of mine told me of another battery which sits between my main car-battery and my amp. Said it will reduce the stress on my main bat, which I can see. Is there a special hook-up which allows draining/stress of this additional battery and not the one in the trunk? I am pretty sure that they would not just be hooked up in parallel.
Thanks!!
I'm a Vagiterian.
Originally Posted by the 7th cj
Thanks all for the responses. Two questions:
Thanks!!
Thanks!!
My battery is just over 4 years old and still going strong.
When it fails I plan on getting the same brand that was installed by Acura.
O'Rileys seems to be the only one,beside the dealer, which sells the Delphi battery. I never had a battery last over four years.
mada51589
05-03-2022 08:54 PM
