Automatic Gear shift locked
Hello everyone. I have recently came across a problem. My gear shift is locking and staying locked when put into park. Im not sure if anyone else has come across this? it the gear shift in need of replacing or is there something else going on? any help would be appreciated. The only way I can take the car out of park is to pop out that little black cap and hold down the white button. Im guessing it is a manual lock release?
well this happened to my old honda accord a few yrs back and it was a switch inside the assembly that was connected to the brake that was the culprit.
honda has a built in safe mechanism with the shift out of park and the depression of the brake pedal.
well the problem stopped with the gear lock, it is able to flow through the gears easily. But now yesterday the check engine light and caution light went on. I was gonna check it out today but now the tranny is slipping bad. I'm guessing that's why the engine light is on? anyways at this point I really don't know what I should do I am considering all options. any suggestions...
trans is on its way out. and the lights are bc of that.
ur options:
rebuilt trans by the factory
rebuilt trans by a shop
or
https://acurazine.com/forums/2g-cl-problems-fixes-70/another-solution-my-auto-cl-guys-758220/
ur options:
or
I dont have a reader, and I really dont want to drive it and further damage anything. I was trying to read on how to read it with putting a paper clip inside the connector holes? does this work?
SidhuSaaB
May 30, 2020 12:40 AM
Pham Alvan
Mar 16, 2016 09:17 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Mike Bertram
Sep 10, 2015 09:27 AM
Sounds like the brake pedal switch
standard sounding.
