Anyone installed the Hawker PC680 Battery in their car?
Go Cowboys.. woo hoo :)
If you have can you can tell me any pro and con's you have experienced? For those who don't know the PC680 is a light weight battery for your car. It will roughly save about 25 lbs of weight off the front of the car. *Based on the stock battery weighing 40 lbs* Here's the URL for more info:
http://www.batterymart.com/battery.mv?p=ODY-PC680
i would guess that battery would save ~ 30 lbs.
VOTE OUT THE BUSH REGIME
# 12 Volt
# 16 Ah @ 10hr rate
# 280 CCA
# 680 Cranking Amps for 5 Seconds
# 28 Minute Reserve Capacity
# Cycle life @ 77°F 400 at 100% DOD
# -40°F to 140°F Temperature Range
I wouldn't bother. This is a very small battery and if you see that the cold cranking amps (CCA) is only 280 this will be a very poor battery for anybody that lives in cold northern regions.
Most batteries have a CCA of at least 600+
And also the reserve capacity is only 28 minutes which is very short.
A couple cranks of your engine and if it does not start you will probably be stuck looking for a jump start.
Other than that it could very well save you some weight that give you quicker times at the track.
# 16 Ah @ 10hr rate
# 280 CCA
Originally posted by AK_MOBBER
# 12 Volt
# 16 Ah @ 10hr rate
# 280 CCA
# 12 Volt
# 16 Ah @ 10hr rate
# 280 CCA
Thanks for the info. I may have to look at a higher capacity battery then.
