Any storage tips?
Old Jan 18, 2001 | 09:09 PM
Gizmo's Avatar
Any storage tips?
I put my CL-S up for the winter back in mid December. Last week I decided I better start it up for a while just to get the juices flowing. The next day I went to my Acura dealer and asked him if I should be doing anything different.
He advised me that starting the vehicle without driving it could cause either the gas to get contaminated with oil or vise versa I can’t remember, because not driving it doesn’t allow it to hit the higher rpms. He said instead of starting it I may want to just get a battery charger.
Does that sound correct or is there something else I should be doing. Has anyone else parked his or her CL-S for the winter?
2001 CL-S Red/Ebony w/Nav
Old Jan 18, 2001 | 11:07 PM
gto2050's Avatar
Someday pigs WILL fly!
<font face="Verdana, Arial" size="2">Originally posted by Gizmo:
</font>
He's right. When you put it up you should have put Sta-Bil in the tank, raised the tire pressure and use a battery "maintainer" not trickle charger. They tend to overcharge. Del Tran makes a very good one for about $60 that will not overcharge your battery. As hard as it is, don't start it without driving it at least 10 minutes or miles. You want everything to heat up. Moisture gets in the exhaust, oil, and all kinds of places that you don't want it. Ten miles of driving should be enough to burn it off. I store my 68 Pontiac from November to May every year and I do just that.
01 CL-S NightHawk Black/Ebony Bowling Ball Interior
[This message has been edited by gto2050 (edited 01-18-2001).]
Old Jan 18, 2001 | 11:21 PM
Geoff's Avatar
8th Gear
crack both doors and the moonroof a bit to allow a bit of air circulation. this helps prevent windshield fogging and residues when the resins sublime (a ordinary process).
Old Jan 21, 2001 | 12:05 PM
Gizmo's Avatar
Thanks for the tips.
baelim
May 10, 2018 09:53 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
dirleton
20
Oct 16, 2015 01:48 PM
Desert Ridge
Sep 27, 2015 02:37 PM
ivan06106
Sep 26, 2015 04:38 PM
