An Answer for ACURA
Old Jan 11, 2002 | 10:54 AM
bone_stock's Avatar
An Answer for ACURA
The following is a quote from an ACURA advertisement in last weeks S.I. If you haven’t seen it picture the CLS winding through a twisty road somewhere in Az. At the bottom of a 2 page picture the ad. says:
“Whose bright idea was this? Right when the race bred V-6 VTEC engine is hitting its stride, the 4-wheel double wishbone suspension is carving every corner and the ACURA/BOSE music system with its 6 disc CD changer is joyfully blasting away, it suddenly appears out of no where. A red octagonal piece of metal stubbornly ordering you to hit the brakes. Really, is there any justice in this crazy world?"
To answer your question ACURA, NO! There is no justice to have the CLS capable in every other way except for the sorry ass brakes!!!
Old Jan 11, 2002 | 11:17 AM
Mike's Avatar
we should have a warped rotors club. had mine turned @ 12k miles.
Old Jan 11, 2002 | 11:39 AM
JasonT's Avatar
Almost 4K miles, & my brakes are great! Lot's of feel, no dust, no warpage, & it does stop very well.
Old Jan 11, 2002 | 12:35 PM
JZ's Avatar
JZ
And, this is on a CLS?
I had mine replaced at about 24000miles and the feel has always been spongy. Too bad the Brembos are SOOOOO expensive and require new wheels.
Old Jan 11, 2002 | 01:10 PM
bone_stock's Avatar
Give it time. I could say the same thing at 4k. Well . . ... not the "no dust" part. Unless they've changed the rotors at the factory you'll have the same rotor warpage problem as every one else. The dealer trued my rotors (no change) at 20k miles. Here I am at 30k miles and they need to be trued again. The ad. I mentioned above speakes volumes to long term CLS owners!
Old Jan 11, 2002 | 01:20 PM
Simpleman's Avatar
the last one alive
I have 16k, and my rotors warped about 2k ago. I'll take it in sometime in the future.
On a related note, have some of you noticed that your car's brakes stops better than other times? I can't find any patterns (outside temp, frequency of braking, etc), but it seems that sometimes the brake "feels" really solid and tight, and other times, it feels a bit spongy.
Old Jan 11, 2002 | 01:36 PM
HebrewNational's Avatar
Fellas, just had mine resurfaced for the second time yesterday! This time they said they would give me new ones. After they finished I looked at the paper work and it showed that they were not new at all but resurfaced. I asked them about this and they said dont worry about it. Like this is even a fuking answer to " where the hell are my new rotors ". " excuse me sir where is your head ? "........" yes "------has nothing to do with the question!!!!
ok i am pissed sorry guys, going back over to www.ar15.com
Old Jan 11, 2002 | 01:37 PM
Chrisbert's Avatar
MP Video Extraordinaire
They fade quite easily when they heat up. I got new pads on mine the other day - did it myself - and I was testing them near my house. I got them so hot that spit sizzles on the rotors!
Old Jan 11, 2002 | 01:38 PM
oh! I only have 26k on my car and dont drive it hard at all....cept for that one time but I thought the blue lights meant go faster!!!!
Old Jan 11, 2002 | 01:53 PM
GRF's Avatar
GRF
There is a service bulletin out regarding Brake Pedal Pulse for our CLs. Might want to ask the dealer about it. The service bulletin number is 01-017. Good Luck
Old Jan 11, 2002 | 02:09 PM
ThoroDredCLS's Avatar
Shift_3.5 Auto
All of you with bad brakes.....
You guys need to upgrade the brakes pads. I didn't check the service bulletin but, if you are going to get your cls serviced....get the upgraded brakes = FREE! Covered under Warranty! ACURA HAS NO SAY ABOUT THAT. REQUEST the new brakes. I feel a big difference and I only had them for 30 miles
Old Jan 11, 2002 | 02:12 PM
JZ's Avatar
JZ
I wonder if new pads with the drilled rotors from ACP would be a good idea at this point. If nothing else, the reduced heat should be a plus.
Old Jan 11, 2002 | 02:41 PM
Zapata's Avatar
Cost Drivers!!!!
Re: All of you with bad brakes.....
upgraded brake pads or entire brake system?
Old Jan 11, 2002 | 04:09 PM
Nitin's Avatar
But I just got here
I'm pretty sure this only applies for cars with certain production dates or VIN's. Kind of like the problem with the tubing for some windshield washer systems.
jjgoblue33
Nov 26, 2015 12:39 PM
Koff
Sep 9, 2015 02:55 PM
asahrts
Sep 4, 2015 05:55 PM
DRR98
1G RDX Problems & Fixes
Sep 2, 2015 10:52 AM
bailey24
Aug 31, 2015 05:38 PM
