Another Broken Key Lock!!
Old Aug 17, 2004 | 07:00 PM
VeeralS05's Avatar
I NEED MONEY!
This is my second one and its keeping me from painting m front calipers and its driving me insane!!!
Incase the pics dont work click here and scroll to the bottom
Old Aug 17, 2004 | 07:11 PM
NiteQwill's Avatar
Adventurist.
You need to get McGard locks...
Old Aug 17, 2004 | 08:43 PM
VeeralS05's Avatar
I NEED MONEY!
where to find?
i tried again and i got 2 lugs off, but the others are comming off since its splitting open the key doesnt grip on the bolts good enough and i might strip the bolt so i'm not going to try...
Old Aug 17, 2004 | 08:55 PM
VeeralS05's Avatar
I NEED MONEY!
I need my front calipers painted, and my car washrd, waxed and polished, plus i have to clean the interior all by friday 3pm. And i have class everyday 845-325 and work 4-7 wednesday and thursday....
WTF am I going to do? Is there a way i can get the key welded back together? some give me some suggestions i'm willing to do about anything...
Old Aug 17, 2004 | 08:58 PM
Chopsie's Avatar
Beware of leakage
I know this agony, I had this same problem with my former car, damn what a pain.
Old Aug 17, 2004 | 09:00 PM
VeeralS05's Avatar
I NEED MONEY!
Old Aug 17, 2004 | 09:46 PM
VeeralS05's Avatar
I NEED MONEY!
some1 please answer my question...can it be welded back together
Old Aug 17, 2004 | 09:54 PM
NiteQwill's Avatar
Adventurist.
http://www.mcgard.com/automotive/
Best locks you can ever buy, also, if you lose or break a key, they replace it! Lifetime warranty.
As for welding, you can give it a try, but if your locks have a low tolerance of space, they newly-welded key will not fit.
Old Aug 18, 2004 | 03:01 PM
VeeralS05's Avatar
I NEED MONEY!
damn yeh, i got another1 on order it should b here in 15 mins...
Old Aug 18, 2004 | 03:56 PM
Dead-Fox's Avatar
15minutes? who did ya order from?? another thing- do you have a welder? Its certainly worth a try.. just don't weld your fingers together!
Old Aug 18, 2004 | 08:31 PM
VeeralS05's Avatar
I NEED MONEY!
got the wheel key got all the lugs off and i've started painting the calipers, they are a bitch to clean, but the paint isnt sticking very well, so i will have to put quite a few coats....i'll be up all night...
Old Aug 18, 2004 | 08:37 PM
NiteQwill's Avatar
Adventurist.
If your paint is not sticking initially, you will have problems with it a few weeks from now. You don't want burned-paint on your wheels. How did you prep the calipers? Did you sand them? Sticking additional coats will not solve your problem of paint sticking, it will only further it.
When I painted my calipers on my other car, I used brake cleaner, a wire brush, steel-wool, and aluminum polishing brush, 100, 200, 300, and 400 grit sandpaper to smooth the roughness and raised portions. Took about 2 days from prep to finish. I then added a high-temp adhesive to the paint, let it sit for 20 minutes, then painted the caliper with 3 coats using a sponge brush. 4 years later, the calipers are still bright and shiny like day one.
Old Aug 18, 2004 | 09:56 PM
VeeralS05's Avatar
I NEED MONEY!
well i used soap and water first to clean the caliper, than i noticed that wasnt working well...
Than i used bleach stuff and sand paper..... Than i let it dry off and used some 500 degree paint on it... I painted my rear ones awhile back abt 2-3 weeks ago and they are still fine... jst a little dirt which i can blast off w/ the water hose...
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
malvothegreat
Sep 29, 2015 12:38 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
