View Poll Results: the question is did you buy boost and FP guages for your car because
it looked cool in cabin
0%
Voters: 5. You may not vote on this poll
All S/C CL-S owners...............
... i bought a boost & fuel pressure gauge so I could monitor what was going on under the hood instead of guessing and blowing up my motor.
and now I got a A/F gauge to add to the collection so I will know exactly what is going on..
How can you blow up the motor if the CT charger is so conservative on the boost. Is there an inherited weak link in the actual S/C kit that will make the car starv from fuel that makes us have to monitor the FP. My bottom line question would be, Is the need for the guages due to the fact that some of the members have altered the original CT S/C kit parameters to get more HP leading to fuel pressure problems or does the kit has problems out the box itself.
Originally Posted by Smitty
I bought a boost & fuel pressure gauge so I could monitor what was going on under the hood...
The gauges help remove all that "2nd guessing" on what might be wrong when/if something does happen.
If your belt is slipping and your making lower then normal boost you'll be able to accurately tell right away. And if your FPR is going south, again, you'll know right away.
13.68 @ 102.56
Originally Posted by darrinb
a negative is that u guys arent sleepers anymore w/ those guages
Bleed Honda Blue
, A/F, Fuel pressure guage, techs, V-AFC and etc. Yet they have no more than a CAI in their car.
well not if you have tints.....
and at night I wired the gauges so they dim with the dash lights.....
So I could be sleeper when need be.....
Gauges were bought because they are a MUST with the Comptech S/C setup. Doesn't matter how "conservative" the stock pulley is. If your fuel pump or FPR gets fouled up you are dead in the water.
I dunno which answer to pick.
Since this applies to other FI people (well, the two - soon to be three) of us on here... I'd say the only reason I have the FP, Boost and a WB is for tuning and a safety precaution. I always look at my guages and if something doesn't look right, I am informed about it.
RSpyder
09-30-2015 12:46 AM
