ALky installed finished.
Japtrix did a fantastic Job tuning the Uni-chip to apply to the Meth + 9 lbs of boost setup. CAr runss amazing and pulls incredibly hard now. I dynoed at 340 WHP and 300 tq. I know a lot of TQ!!!!! he couldnt believe it either! They actually took away a ton of fuel in the tune and my fuel pressure actual went down to 90 PSI at WOT wich is better than when I was running the HBP. overall there is less load on the fuel system. The actual ALky kit is seemless. You dont even know its there excpet for a few more indicator lights on my boost gauge for a low lever of meth indicator and a "alky on" indicator. When I took it for a test drive I couldent believe how hard it pulled. I didnt even get traction through 2nd gear!
The only negative is that I have to fill up the reservior every couple weeks, but i dont care. I will post some pictures soon of the car. I have a lot of new stuff that you guys havent seen, including new wheels.... Anyway If anyone is looking for some more power with the S/C get the meth kit from alkycontrol and you will love it. by the way im running 9.5 lbs of boost.
yeah. I was anxious to wait and see if the uni-chip would work but as japtrix stated they could tune it just fine, and they did. Cocoa, I do plan on going to moroso on wedsday. Ill post some time slips.
That's very good! I was always wondering what the number would be with a good tune with methanol injection. On mine, I just used it to supplement the fuel but wonder what it might have done if tuned for it. I was always running a little rich. What you've done with it is one of the best mods for the supercharger I've seen without putting on the water IC. You've done what they've done without the hassel and expense.
Originally Posted by BlackV62K2
Are you still running stock injectors and the CT fuel pressure regulator? What's your warm idle fuel pressure at?
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
