Alignment Problem?
Alignment Problem?
Has anyone with aftermarket wheels have problems even after getting an alignment? my car is still pulling to the right. a problem i have everytime i put aftermarket rims on a car.
My car pulls to the right with stock setup. Already aligned once after 3 months. It's been another 9 months after that first alignment and it's pulling to the right again for me. I was waiting to put springs on before I realign, but money is tight so I may just align.
I noticed that my car pulls to the right with my aftermarket rims and tires. I have had two or three alignments since lowering and then raising back to stock (long story), the car still pulls to the right. Firestone said it is pulling to the right because of the tires and I have S03, maybe because of uneven wear.
yea the place i took it at did a great job. they even gave me a read out. i mean the pull to the right was a lot better then before i got it aligned but its still bad enough that i can let go of the steering wheel and it will pull to the right in a couple of feet.
Re: Alignment Problem?
no curb guard man. the alignment was done. i just can't figure out why its pulling to the right still..
Usually the first thing an alignment shop will do is switch tires and check PSI if your car pulls after an alignment.
You could switch the tires just to see if that's the problem. It won't hurt the tires. The tread is just for wet weather driving otherwise we'd all be on slicks
Most of the roads are crowned so any car will pull to the right. Does it still pull in the farthest left lane?
Dan
Dan
I have the same problem, the car has a very noticable pull to the right. As soon as I let go of the steering wheel it immediately goes right, even the steering wheel will turn right on its own.
I had 2 Acura dealers take a look, including PAA. The final result they both said its the sport rated tires. I had alignments, re-balances, even a new front right tire, all pulls. But when I swap it with the rear tire, the pull is not as bad. So I thought it may be a bad rim. I have 2 spare rims (in case of scratches). But PAA didn't even check the rim when I was there last week for the 30k service. They just said it was the sport tires and the alignment is in perfect factory specs.
So on my own I may have the rims switched and see what happens.
SidhuSaaB
05-30-2020 12:40 AM
