70mm throttle body?
Old Mar 15, 2013 | 02:51 PM
PhoenixCL-S's Avatar
70mm throttle body?
I am doing a build on my 2001 Cl-S this summer and one of things I am looking for is a new throttle body. I did some research on 80mm throttle bodies but that seems like way to much of a hassle. Is there any 70mm bolt on throttle bodies?
Old Mar 15, 2013 | 04:32 PM
richardparker's Avatar
3.7L Nitrous Breathing CL
OBX are closest thing.
The universal's are a pita.
I think i'm starting to have a shaft leak on mine. I have another to replace it but, I don't want to because of the work needed to make the map setup alone.
Old Mar 15, 2013 | 04:49 PM
So pretty much replacing the throttle body is to much of a hassle? Is it possible to bore out the stock throttle body to around 70mm?
Old Mar 15, 2013 | 04:57 PM
I think they can be bore 2-3mm larger than oem.
I would try the 76mm blox and you will only have to make something for the icav witch is not very hard.
I meant blox before too not obx.
Old Mar 15, 2013 | 06:54 PM
clsallmotor01's Avatar
you can put any honda b-series throttle body on it will work. its bolt on the only thing you gotta do is buy p2r throttle cable bracket and iacv adapter that they sale together , or modify your own throttle cable bracket and make your own iacv adapter, and also port match the thorttle body to your intake manifold. Throttle bodys you can buy are skunk2, blox, bdl, omni,
Old Mar 15, 2013 | 07:34 PM
gnuts's Avatar
3.5 psi
isn't our oem TB like 68 or 70mm already? If you only want a 70mm then get the oem one bored out by maxbore.
Old Mar 15, 2013 | 07:49 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
Stock type s is only 66 you can get it bored out to about 68-69.
Old Mar 15, 2013 | 08:37 PM
progression's Avatar
If i wanted to use a thermal gasket for the blox throttle body would i get one for the b series throttle body? Thanks
Old Mar 15, 2013 | 08:56 PM
clpassenubye's Avatar
ABP-KBP-CBP & ME
Our oem is 64 and I contacted maxbore and he said he can only do up to 68 on our TB's
Old Mar 16, 2013 | 02:07 AM
yes you would get one for the b-series throttle body just make sure its the same size as your throttle body
Old Mar 16, 2013 | 11:54 AM
h22cd7's Avatar
I have a 70mm Skunk2 from my h22, i have a j35a7 manifold though
Old Mar 16, 2013 | 01:03 PM
CL-S progression 01's Avatar
lowrd on tein CS biatch
How much power would upping the tb size 10 mm get a CL with all boltons?
Old Mar 16, 2013 | 03:53 PM
fsttyms1's Avatar
I might try this one, main reason is it has BOTH cable wheels so you can retain cruise control. None of the other ones allow you to.
http://www.hybrid-racing.com/store/h...ttle-body.html
Old Mar 16, 2013 | 03:57 PM
fsttyms1's Avatar
These motors LOVE air. The more you can get them the better. 80 seems to not even be enough and why a few are running twin stock type-s tbs.
Old Mar 16, 2013 | 05:03 PM
If this bigger tb business added another 10 hp I'd do it
Old Mar 16, 2013 | 06:55 PM
fsttyms1's Avatar
with every thing else it does.
Old Mar 18, 2013 | 01:51 PM
03CLSMT's Avatar
just get the 76mm blox b series its bolts up fine just have to put the throttle bracket on a little different... install should only take about and hour and its a huge difference in power if you have other breather mods
Old Mar 18, 2013 | 01:52 PM
03CLSMT's Avatar
best mod ive done ( minus xs headers)
Old Mar 18, 2013 | 04:43 PM
did it bolt up nice?? any idle issues??
do u use the tps it comes with or the same one off the old tb.
does all the piping fit over it still?
does our iacv bolt up to it?
i am highly considering this mod if it's not too labour intensive.
i am jonesing for another HP MOD
oh and... do i need to the port out the manifold then??
Old Mar 18, 2013 | 05:06 PM
fsttyms1's Avatar
There would be no point in it with the stock manifold You would have to have teh 09+ intake manifold.
Old
what piping
No, you have to do some custom work for it to work
not if you use the 09+
Also with the Blox, you loose your cruise control.
Old Mar 18, 2013 | 07:09 PM
ok so it's not easy as i had hoped. ah well
Old Mar 18, 2013 | 09:07 PM
gnuts's Avatar
3.5 psi
i'm considering doing this mod. I'd have to port the blower a little bit i'm guessing too. Would this be worth while with the s/c'er?
Old Mar 19, 2013 | 01:58 AM
on the blower it would make a big difference
Old Mar 19, 2013 | 02:04 AM
Its actually simple to do if you know what your doing.
The only way to get the most gains out of the bigger throttle body is to port match the manifold but the cls manifold you could only port it open so much.
Old Mar 19, 2013 | 02:11 AM
rush's Avatar
03 acura cl type s
You can start with this & improve TQ @ every rpm
Old Mar 19, 2013 | 06:22 AM
fsttyms1's Avatar
And its not hard either. Its just not a simple remove 2 bolts and replace like it sounds like you want it to be.
Old Mar 19, 2013 | 02:55 PM
im in school now for furniture design and i got a job. both of which require my car when i need it which needs to be reliable.. and I don't like tinkering with my ride.. There is nothing more annoying than doing a mod only to create problems.
If there is one promise I made myself with this car, that is. To not cause a problem by trying to mod the car.
Which happened with my suspension cause now there is a dirty knocking noise when going over bumps coming from the back (because the bolt that connects the shock to the rest of the suspension has play in there). (we are talking about half a millimeter but that's enough for it to knock around when going under 60km/h). All i need to do is make some bigger bolts.. or something!!!
that pisses me off enough and it's not even interfering with the drivability. if i had a wonky idle i'd go balistic
Old Mar 21, 2013 | 09:46 AM
brian6speed's Avatar
Lone Wolf
What is the maximum the oem manifold can be ported? I have mine ported but can't remember off the top of my head.
That hybrid racing tb is very nice, but very expensive also considering I don't use cruise control.
Old Mar 22, 2013 | 11:14 AM
03CLSMT's Avatar
whoa whoa whoa,
hold on dont get discouraged the tps sensor comes with it and it works fine, the iacv u can just use a block off plate and it runs fine....i rigged mine so it kind of surges a LITTLE but nothing crazy its not bad enough for me to make a better one. its very simple.... only other thing i did to my manifold was port it with a dremel with no micro meter and crappy bits to get close to matching the inlet size.
I had this car in college when i was broke so i went the cheap route on everything muffler shop 3" exh (try to minimize the bends and dont Y the exh for looks, leave a dummy muffler if u want the looks) with 2 resonators and xs headers , pullies, 4" pvc intake dynoed at 265 whp ....my mods cost less than 1500 ... some people spend that one exh set up. im not knocking them they have better quality bends and welds but this is my car and how i wanted to mod it
Old Apr 2, 2013 | 02:10 PM
gnuts's Avatar
3.5 psi
Found A 70Mm Tb for Sale I Think I Might Grab....Port The Blower inlet To Match. a
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
