5300rpm rev bouncing problem. help!
Old Apr 27, 2007 | 11:41 AM
mohaukachi's Avatar
upgrade
hey, still on my first week of owing this car. i raced my buddy in his 330ci 6mt the other day and while i did beat him, i noticed a really weird thing. on my way up revs in both first and second, it felt like the car hit the rev limiter at 5300 rpm i thought i was just not glancing at it at the right time so i had my friends in the car watch the tach and ran it again. same thing i would get to 5300 and it would wub wub wub wub and not rev any higher!!
my thought is that since im the second owner the computer has goten used to the first owners driving habits i dont really know tho. i really need help on this one! what's going on with my new baby!!
PS. i let my girlfriend name her.... wait for it... BOSS BITCH!
Old Apr 27, 2007 | 11:52 AM
SuperTrooper169's Avatar
In the Mid-South meow
Hmmm, definitely sounds like something's off there. How could you beat a 330i with the car only going up to 5,300 RPM. Just doesn't add up. You sure you not just experiencing the VTEC kicking in at 4,800?
Old Apr 27, 2007 | 11:54 AM
phipark's Avatar
Not Asian
Sounds like VTEC isn't engaging. Check the oil. I bet it's low. My brother had a problem when the dealership forgot to put oil back in his Accord.
Old Apr 27, 2007 | 11:56 AM
mohaukachi's Avatar
upgrade
im about to head in for my 60,000 in 700mi. i figgure i can get it sorted out there, but low oil could do that?
Old Apr 27, 2007 | 11:58 AM
mohaukachi's Avatar
upgrade
i do feel the vtech kick but this is like hitting blockage... just like hitting redline but 1k early.
phipark's Avatar
Not Asian
Yep, but when I mean low, I mean almost none.
Old Apr 27, 2007 | 12:17 PM
GreenMonster's Avatar
Yes... there is an oil pressure sensor that will tell the ECU if it can engage VTEC. Low oil pressure (low oil) equals no vtec...
https://acurazine.com/forums/showthr...=pressure+vtec
I can rev out to a little over 7200 rpm on my 6spd, so you definitely have something screwy going on...
Old Apr 27, 2007 | 12:29 PM
mohaukachi's Avatar
upgrade
woah... im going to check that right now. thanks guys.
i know the CLS is a step up from my 97 cl 2.2 but dayum. if all this week ive been driving with no vtech and been loving it, i cant imaging what ive been missing... lol.
Old Apr 27, 2007 | 12:43 PM
fuzzy02CLS's Avatar
Yeah man your car is broke. No CL should do that. Maybe your tach or tach signal wires is busted.
Old Apr 27, 2007 | 01:00 PM
spdy0001's Avatar
I now drive an accord....
Yup you will love the car even more once you can get the full power out of it.
Now PLEASE change your avatar before it gives someone a seizure
Old Apr 27, 2007 | 01:04 PM
mohaukachi's Avatar
upgrade
lol sorry bout that... guess i got carried away.
Old Apr 27, 2007 | 01:38 PM
CleanCL's Avatar
no CELs? this is strange. reset the ECU.
Old Apr 27, 2007 | 03:16 PM
rtatsutani's Avatar
Never had a clean run
Oil. I did the same thing, thought it was serious, then typeR said check your oil, I thought noways and
Old Apr 27, 2007 | 04:35 PM
mohaukachi's Avatar
upgrade
ok checked it... if the oil is supposed to be above to two holes on the dipstick then im good on oil. ill try the ecu reset... ill need radio codes for that right? this is a canadian CL so the the code might get tricky... lol.
Old Apr 27, 2007 | 04:40 PM
PimpCL23's Avatar
contrarian in fashion
i had the same problem with my car.
i checked my oil level and it was kool too.
i checked the vtec solenoid to see if it was dirty (and re-cleaned it anyway) and that was also fine.
The thing for me that wasnt allowing my Vtec to engage was a HUUUGE dent on my oil pan. that dent cause the lack in oil pressure for me. Check ur oil pan to see if u may have bottomed it out anywhere or hit a rock or dead person on the road to dent it
Old Apr 27, 2007 | 05:19 PM
LiquidCLs6's Avatar
ya i hate it when those dead people get in the way and F up my car!!
Old Apr 27, 2007 | 05:20 PM
visuelz's Avatar
East Coast Crew
It sounds like you hit the gas really hard that caused the rpms to shoot really high before it hit could hit a certain speed that will prevent the fuel cutoff to disengage.
Old Apr 27, 2007 | 05:27 PM
mohaukachi's Avatar
upgrade
no dents and the oil cap is on good and tight. what about the oil filter... could the last oil change place have put on a filter thats too small? like put a CL-p filter on?
Old Apr 27, 2007 | 08:20 PM
Accord_V6_400m's Avatar
4drs just wanna have fun!
Interesting, right now my car when its warms up and goes into open loop system doesn't want to go past 2Krpm, I get a crank sensor DTC checked the tranny crank sensor and its good
Old Apr 27, 2007 | 09:28 PM
BigLizard's Avatar
Moderator Alumnus
I would think that his car is in limp mode and no CELs are being thrown...it can happen.
Old Apr 27, 2007 | 09:46 PM
Check Kris' (fsttyms1) thread over in the 2G TL forum. IIRC he had the same issue when he put the 6spd and typeS engine in his TLP.
https://acurazine.com/forums/ramblings-12/my-job-132196/
Old Apr 27, 2007 | 11:53 PM
mohaukachi's Avatar
upgrade
https://acurazine.com/forums/showthread.php?t=132196
haha... what page.... theres over 40. so im guessing this is one i should let a real mechanic handle?
oh and i watched the tach on the way home, it dies at 5500 exactly.
Old Apr 28, 2007 | 12:08 AM
Thanks for the info, I started reading through it we'll see if I find it
Its weird because for me it happened after I did a UIM port and polish, oil change and valve adjustment.
At first I thought it might be the engine wire harness that goes above the rear valve cover.
Old Apr 28, 2007 | 12:42 AM
CleanCL's Avatar
its time to do a pinpoint wire check. some critter may have be chewing at your wires.
Old Apr 28, 2007 | 01:25 AM
I guess it came down to the front cam gear and the cam sensor clearances. I have the 6spd parts but maybe it screwed something up when I was rpotating the front cam gear to get every cylinder to TDC.
DerrickW
Nov 15, 2015 05:52 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
thegipper
Sep 28, 2015 01:01 PM
ceb
ILX
Sep 27, 2015 10:56 AM
prbori
Sep 27, 2015 01:37 AM
