5300rpm rev bouncing problem. help!
hey, still on my first week of owing this car. i raced my buddy in his 330ci 6mt the other day and while i did beat him, i noticed a really weird thing. on my way up revs in both first and second, it felt like the car hit the rev limiter at 5300 rpm
i thought i was just not glancing at it at the right time so i had my friends in the car watch the tach and ran it again. same thing i would get to 5300 and it would wub wub wub wub and not rev any higher!!
my thought is that since im the second owner the computer has goten used to the first owners driving habits
i dont really know tho. i really need help on this one! what's going on with my new baby!!
PS. i let my girlfriend name her.... wait for it... BOSS BITCH!
i thought i was just not glancing at it at the right time so i had my friends in the car watch the tach and ran it again. same thing i would get to 5300 and it would wub wub wub wub and not rev any higher!!my thought is that since im the second owner the computer has goten used to the first owners driving habits
i dont really know tho. i really need help on this one! what's going on with my new baby!!PS. i let my girlfriend name her.... wait for it... BOSS BITCH!
Hmmm, definitely sounds like something's off there. How could you beat a 330i with the car only going up to 5,300 RPM. Just doesn't add up. You sure you not just experiencing the VTEC kicking in at 4,800?
Originally Posted by mohaukachi
im about to head in for my 60,000 in 700mi. i figgure i can get it sorted out there, but low oil could do that?
https://acurazine.com/forums/showthr...=pressure+vtec
I can rev out to a little over 7200 rpm on my 6spd, so you definitely have something screwy going on...
woah... im going to check that right now. thanks guys.
i know the CLS is a step up from my 97 cl 2.2 but dayum. if all this week ive been driving with no vtech and been loving it, i cant imaging what ive been missing... lol.
Originally Posted by spdy0001
Yup you will love the car even more once you can get the full power out of it.
Now PLEASE change your avatar before it gives someone a seizure
ok checked it... if the oil is supposed to be above to two holes on the dipstick then im good on oil. ill try the ecu reset... ill need radio codes for that right? this is a canadian CL so the the code might get tricky... lol.
i had the same problem with my car.
i checked my oil level and it was kool too.
i checked the vtec solenoid to see if it was dirty (and re-cleaned it anyway) and that was also fine.
The thing for me that wasnt allowing my Vtec to engage was a HUUUGE dent on my oil pan. that dent cause the lack in oil pressure for me. Check ur oil pan to see if u may have bottomed it out anywhere or hit a rock or dead person on the road to dent it
Interesting, right now my car when its warms up and goes into open loop system doesn't want to go past 2Krpm, I get a crank sensor DTC checked the tranny crank sensor and its good
https://acurazine.com/forums/ramblings-12/my-job-132196/
Originally Posted by GreenMonster
Check Kris' (fsttyms1) thread over in the 2G TL forum. IIRC he had the same issue when he put the 6spd and typeS engine in his TLP.
https://acurazine.com/forums/showthread.php?t=132196
haha... what page.... theres over 40. so im guessing this is one i should let a real mechanic handle?oh and i watched the tach on the way home, it dies at 5500 exactly.
Its weird because for me it happened after I did a UIM port and polish, oil change and valve adjustment.
At first I thought it might be the engine wire harness that goes above the rear valve cover.
Originally Posted by fuzzy02CLS
Yeah man your car is broke. No CL should do that. Maybe your tach or tach signal wires is busted.
Thanks for the info, I started reading through it we'll see if I find it
DerrickW
Nov 15, 2015 05:52 PM
