2003 CL-S 6speed Motor Swap Issues
I recently picked up a 2003 CL-S with 100k miles at auction. Turns out the motor was blown, no compression in 2 cylinders. Did some quick browsing online and found a motor that would supposedly drop in and go. (By verifying vin number). I admit I should have done a bit more research, however, I have the new motor in and am running into issues with the wiring harness.
It seems the new motor is a j32a1 auto and the original CL-S motor is a j32a2. Am I going to have to use the wire harness from the new motor? And will it work with the CL-S ecu? Are there any other things I am going to have to do/swap? Swapping this motor was a nightmare and I am not exactly looking forward to pulling this out again so I would like to keep the j32a1 motor in here now.
Any help is appreciated, thanks.
These two threads may help you with part of your issues...
https://acurazine.com/forums/2g-tl-1999-2003-98/02-tl-s-swap-issues-855850/
https://acurazine.com/forums/showthr...ht=J32a1+J32a2
There may be some info in these...
https://acurazine.com/forums/2g-tl-performance-parts-modifications-116/engine-tranny-swap-621394/
https://acurazine.com/forums/2g-tl-1999-2003-98/well-ladies-time-has-drawn-near-756856/
you have a non type s motor. You might as well ditch that and get a type s motor (J32A2). Why bother trying to get a motor working with quite a bit less horse power into your car?
Get a J32A2 motor and then you'll have to swap a few parts from the 6speed motor to the auto motor.
Dont put the A1 in. It will be a waste of your time and money. Get a A2. Doesnt matter if its from a auto or not. If you have your original motor all you have to do is swap over the crank position sensor and the TDC sensor and front cam gear.
gear behind the crank pulley and sensor are different
auto head needs to be grinded a bit to fit 6 speed sensors
thats 6speed head front cam
thats auto head front cam after the grind (i used dremel)
auto motor has extra water line that goes into tranny which needs to be blocked or swaped from 6 speed
