2001 cls braking problems?
Old Nov 2, 2003 | 05:59 AM
azn style 2005's Avatar
7th Gear
i warped the rotors 5000 miles into the car and now with about 50,000 miles on her (mind you still first tranny) i notice a problem again with brakes. every time i brake at high speeds, usually 55+mph, the steering wheel shakes. the shaking stops after a few seconds when i'm cruising around 40-45 mph with steady brake. the rotors seem ok and aren't scratched or anything like that. what could the problem be?
Old Nov 2, 2003 | 06:14 AM
CO-CL-S's Avatar
Most likely your rotors are warped. What was done to them at 5,000 miles? Did the dealer replace the pads (that's supposed to be the cause of the rotors warping prematurely)? If not bring the car into Acura and mention TSB 01-017, even if the pads were replaced at 5,000 miles you may still get a dealer to do it again and turn your rotors. YMMV
mada51589
Jan 9, 2025 04:40 PM
02tljj
May 2, 2019 08:56 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
3.5RLv-tec?
1/2G MDX (2001-2013)
Sep 7, 2015 11:00 PM
