Need help!! for Wheel Nuts
I bought a set of used Volk Racing GTC wheel and tire. Howver, they didn't comes with nuts. I went to a few performance store, they said they have to special order it.
Do you know where I can get the nuts from the internet store? Thank you for you help.
This is how the lugs looks like:
ATCer
Bye TSX, hello domestic?
what is it about these nuts that they have to be so special. there is oem nuts and tuner nuts, that's about it. you do need different lugs, but nothing that special
ATCer
Your stock lugs will NOT work on a set of aftermarket wheels. Honda has a different lug set-up, which is the problem I ran into when getting my wheels (tapered tip vs rounded). The Spoon lugs I got were designed for Honda and Spoon wheels (rounded) Rays and others are tapered.
Originally Posted by vwong
If you look at the holes for the lug nut closely, they're very small. I doubt the Rays nuts would fit because a 19mm socket might not be able to fit in those holes. Therefore, the lug nuts have to be smaller. In the old days, people use open-end socket style lug nuts. Now, you can either use the Kyokugen lug nuts or the Spline Drive lug nuts by McGard (http://www.mcgard.com/automotive/new_prod.asp). These lug nuts require a special socket that would fit in holes like the ones in the GT-C.
Originally Posted by hbux
Thanks for the link.
Do you think this kind of nuts will fit?
THREAD SIZE : M12 x 1.5
HEX SIZE : 13/16"
SHANK DIA : 0.679"
HEX SIZE : 13/16"
SHANK DIA : 0.679"
Those are to be used with washers and the open end is so the tech inspector at the drag races can see that the stud is long enough. The plastic cap is used to keep water and debris from getting on the thread. For RWD Crager, Center Lines, or Weld wheels.
They won't work.
You might try these
http://cgi.ebay.com/ebaymotors/ws/eB...category=33749
Any wheel place should have something like these and cheaper. Pep Boys has them.
Thanks for the guide from everyone. However, i still haven't find the lugs ...
Wish me luck...
I already have the M3 lip. After the wheel , I will get the A spec suspension.
Wish me luck...
I see now what the problem is I did a test fitting for my GT-C ()and neither my regular tuner lugs or mcgard splinedrives fit. the wheels definately need an internally driven lug nut.
Originally Posted by ianS
So how about lugs for TE37? my TE37 will arrive this week and I need to get some lugs too. :gheywave:
you don't need special ones like the GT-C, any tuner ones will work. I have McGard Splinedrives on mine and like them a lot.
how big?
what color?
you can get rays engineering lugs if you want to be .
Originally Posted by dzuy
ANOTHER tsx owner buying TE's?!? oh no!!!
how big?
what color?
how big?
what color?
how big?
what color?
how big?
what color?
Former Sponsor
I may be able to get you a set, but it will take a number of weeks...
The cost is around $120.
Marcus
NOTE: You must use the GT-C lugs....no others will work to my knowledge.
nanos
11-12-2015 08:41 PM
merc009
10-03-2015 12:59 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
