Need Help installing TPMS
Old Oct 19, 2007 | 10:13 PM
crayzo's Avatar
7th Gear
So I got my wheels stolen a couple of weeks back and i finally got replacements. I plan on putting them on myself. I just need help putting the TPM sensors. I beleive i have all the parts i just need some instructions on where to put it and all. Appreciate the help.
Old Oct 20, 2007 | 12:10 AM
TacoBellSauce's Avatar
i belive you just screw it on where the valve stem goes
Old Oct 20, 2007 | 01:29 AM
crayzo's Avatar
7th Gear
i do not have to connect then to anything?
Old Oct 20, 2007 | 06:41 AM
Simba91102's Avatar
Old Guy
It's a wireless system. The sensor just takes the place of the valve stem (it actually is the valve stem). That said, I've never replaced one. I have read here though that the cars' computer may not recognize the new sensor(s). I'd call or visit your dealer's service or parts department; they should be willing to tell you if there's anything else that needs to done (if there's something in the diagnostic computer that needs to be reset for instance). You should share the end of this story, since with the arrival of this system (which I have no use for by the way), I'll guess questions surrounding it will become more common. It would also be interesting to hear from those that have decided to run wheels without sensors on cars equipped with the system (like me). When the snows (not tpms equipped) go on my wife's 07, I'm curious what kind of "the world's coming to an end" message shows up on the MID. Gotta love the nanny state.
Old Oct 22, 2007 | 10:42 PM
WhiteDragon07's Avatar
PWP/ebony/6MT/Navi
My new snows are now on, and my new alloy wheels are tpms compatible but the tire place neglected to transfer the sensors from my stock wheels to the winters. Was going to have them transfer everything, but since the only "end of the world" message that shows on the MID is "Check TMPS system" when you start the engine (disappears except for the "i" when you press the "info" button, I think I'll just deal with it this winter and splurge on new sensors next winter! I check the pressure manually anyway, out of habit. And oddly, I had to drive quite a while before the car realized the sensors were no longer in close range of the car...! Better wireless transmission then many cell phones ;-)
Old Oct 23, 2007 | 08:03 AM
Simba91102's Avatar
Old Guy
I found that too. I went about 4 miles with a couple of the snows on and they weren't recognized as not TPMS equipped. My wife can live the yellow "i".
Old Dec 14, 2007 | 02:49 PM
PKsTSX's Avatar
If I bought aftermarket rims, the TMPS indicator would always be on then correct?
Old Dec 14, 2007 | 04:25 PM
Simba91102's Avatar
Old Guy
If you don't have the sensors installed in the new wheels, then the MID will show the warning each time you start the car. Once you scroll past it, only the little yellow "i" remains to warn you that there is (the system thinks) a low pressure condition. When I changed over to the winters, I went over 40 miles before the system realized the wheels didn't have sensors in them.
Old Dec 15, 2007 | 11:55 AM
PKsTSX's Avatar
So, the sensors can be installed on any aftermarket rim correct? From what I've read, they are the valve stems themselves... So the valve stems are the same size as the normal valve stems? Can you just take the stem out and put it on the new rim?
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
bailey24
Nov 21, 2015 08:43 PM
johnalfa
Oct 31, 2015 12:55 PM
lland
Oct 4, 2015 04:47 PM
TxRzrBk
Sep 17, 2015 01:07 PM
